cabrio roll over safty bars
I have a customer that has 1999 996 cabrio and wants the canvas cover for the pop up bars behind the rear seats recovered. How does this come off? I just finished the ignition replacement. Piece of cake. After some researching thru different places it made it easy. Anyone can do it. Just ask. thanks agian for the help.
You could always tip it over ?
or buy a manual, or take it to a dealer, ill answer anyones questions, except a shop
if you are going to take the responsibity for getting paid to touch someones 100K car
I think you should have the knowledge to do so, especailly something as simple as trim work.
To 99firehawk,
thanks for taking the time to insult me and my question. It was a simple question directed to someone who could answer my question, not insult me. I asked because I care enough not to break someones car. THANK YOU FOR YOUR SUPPORT!!!!!!!!!!!
Then there's that whole issue of Rennlist "members", some of whom have the holier-than-thou attitude with non-paying members. But we won't go there. oops, I guess I just did.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
So, not having done this particular repair before, I really can't help much. I would assume that the material is glued on, so I guess you're just going to have to get some heat and/or solvent and tear that stuff right off. There is a procedure listed in the owner's manual on how to lower the pop-up bars. I don't have the manual handy, so I can't help you out. I can't recall if the manual tells you how to raise them, but there's got to be a way.
Best of luck to you.
Michael
Chandler!
I don't know the answer to the question, but I will say the guy is trying to do the right thing by his customer and I don't know the circumstances behind it so I'm not going to beat up on the guy.
Either way if I knew I would help you dude.
You can also try www.renntech.org great place for all things technical.
If you're just talking about the two oblong covers directly over the safety bars, they are just false covers and simply pop out. Grab from the rear and pull slightly to the front and up. The fabric is just glued on. If you're doing the whole piece you need to remove the carpeted panel behind the rear seats. That involves two Phillips screws. Once that's out, there are a couple bolts that hold the canvas-covered piece to the aluminum cage encasing the safety bars. I am not certain, but there may be similar bolts on the rear side. To get to those, you'll need to put the cab top in the service position and remove the carpeted tray in the top storage well.
Thanks to all who helped with my issue. I try to do everything I can for my customers. There are every few Porsches here put the population is growing. I am the only upholstery shop in town that will touch any kind of car like these. I love Porsches and do what I can to make the customer happy. By the way, the car DID come from a dealer. Thanks again for all that helped.
Mark
Mark
In general why would you take your car to someone who has no experience in doing what you want to get done. Weather its a mechanical issue or cosmetic. This is nothing against the original poster, he might do fantastic work, but as a car owner my first question to anyone that's going to work on my car will be if he has experience with my particular car. If he does not I will go else where.
ya know... if I took my car to an uphosltery shop, I would not be surprised if they told me it was the first time they'd worked on a 996 911. It's not a terribly common car, and since so many are garage queens and the 996 isn't all that old, they may have to "learn" on my car.
Mark,
That should solve your problem. I can't imagine that a Porsche dealer who sent you the car would not be willing to let you take a look at the shop manuals.
When the local dealer sent me to an upholstery shop for top work, the upholstery guy went to his shelf and pulled down one of the 996 volumes to show me what he was going to do.
i send cars to the upholsery shop, With what ever they need taken apart. I would think a phone call to the dealer would be quicker then you posted
"I just finished the ignition replacement"
dealer couldnt figure that out
