Anyone ever run into a situation where engine start up is weak sounding from a cold start? Once warmed up, subsequent starts sound fine. Wondering if there's a bad sensor somewhere?
Previously had dealer check similar situation out under warranty and they replaced the Bank 1 Catalyst (996-113-031-06). Not having any check engine light or other noticeable mechanical impact.
I think that part number is for the catalytic converter. I looked at Pelican Parts. I have a weak sounding engine startup at cold also. No CEL or any sort of broken mechanical sounds. I wonder if I need new cats???
Yup. That's the part number for the catalytic converter, but I think the dealership was pre-emptively replacing it rather than having determined that it was defective. Not sure that we need to replace this.
SpeedPhreak
02 C2 - K&N Aircharger, SSK, Tubi Headers and Exhaust
I'm about ready to clean the throttle body as in the refernced post. Sounds just like the problem I am having. One question......do I need to the the "throttle adaptation" for a 03 996? Cant find anything about "e-gas".
Nice, I love that write up. At first I was a little concerned about the car being difficult to work on (have owned BMW in the past). But am surprisingly happy that this car has been a DIY dream.
Out of curiosity, when you said "turn on the ignition", did you mean to start the car, or just turn the ignition to the pre-start phase? I cleaned my throttle body a while back, but never did this procedure.
Thanks for the compliments on the DIY writeup, guys!
Glad it's helping some people out, eventhough it's a very simple job.
nycebo, it means turn the key to on, no cranking to start.
I'm sure the car's had a chance to adapt by now if you've done it a while.
But you can always do the adaptation procedure anytime, it's kinda like restarting your home computer, I guess?
