996 Forum 1999-2005
Weak Sounding Intial Engine Start Up
Old 08-08-2007, 09:35 PM
evansaero
evansaero's Avatar
Check battery
Autozone will do this for free
Old 08-08-2007, 11:09 PM
michael.s.under
michael.s.under's Avatar
Go to Checker, I went to autozone today to price match. Those guys are dip****s. "Uh, I never heard of 0w40 oil. Hey Gary we got that here". See ya!!!
Old 08-11-2007, 11:19 PM
SpeedPhreak
SpeedPhreak's Avatar
Default Worked Like a Charm!
This DIY worked great! I was initially apprehensive about removing my intake to reach the Throttle Body, but Cosmos' detail was reassuring.
Picked up the cleaner for about $4.18 at Advanced Auto Parts and the cleaning took less than 30 minutes at a leisurely pace. Here are slight modifications for folks with the K&N Aircharger installed:
1. unclamp oil filler (move out of the way)
2. loosen ring clamp for air filter
3. remove air filter
4. disconnect MAF sensor
5. loosen ring clamp holding down the intake tube
6. loosen ring clamp on the throttle body itself
(See photos attached)
Was a little surprised at the butterfly, as it required a little effort to keep it open while cleaning, but the recommended cleaner worked very well.
I also attached before and after shots as well.
Engine is sounding great from a cold start. Awesome DIY. Thanks!
Old 08-12-2007, 12:03 AM
ArneeA
ArneeA's Avatar
You went all the way removing the intake stopped at the throtle body? It only takes the 4 bolts to remove the throttle body and clean it overall inside and out. I just did it this afternoon as well but I removed the entire throttle body and cleaned it with the spray and a rag, front and back, while off the car.
Old 08-12-2007, 01:01 AM
CosmosC4S
CosmosC4S's Avatar
SpeedPhreak, Glad you fixed the problem! And your local dealership is at least $200 poorer
Arnee, I also didn't remove the throttle body to clean, as I was able to clean the back of the butterfly, as well as inside all the way into the plenum, as it is.
Quick Reply: Weak Sounding Intial Engine Start Up
