the red "S" emblem of C4S
Hi guys,
just removed the original "S" emblem from the back of my C4S for a red one. how do i remove the left over glue that was left on the car wihtout damaging the paint? what solvent do you guys recommend?
thx,
John
thx,
John
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
You should be able to get the remaining glue off by rubbing with your fingers.Then use some paint polish. Wax after you apply the new one as you don't want to apply the new "S" on a freshly waxed surface. I switched my "Boxster" logos a couple years ago.
BEFORE:
![](http://i11.tinypic.com/52x4a52.jpg)
AFTER:
BEFORE:
AFTER:
![](http://i12.tinypic.com/541cr3a.jpg)
Hi,
I recently did this as well.....replaced my gray "s" with the red "s"....bought it from that guy on ebay. Anyhow, my red "s" came with an alcohol swab/pad, which removed the glue fairly easily and has no impact on the paint.
good luck and make sure you have the bottom of the "4" properly lined up under the carrera portion just right before you press it down.
J
J
Technical Guru
Just did a search on ebay....can't seem to find the guy who sells them. I think mine was about 25 or 30 bucks shipped. It was a new "4S", but I only used the "s" portion. No cutting needed.
I bought mine from him outside of ebay....I'll try to get his info...I think I still have the box. I had it 2 days after I paid.
J
J
Newbies Hospitality Director
Originally Posted by TheSpeedDemon
So what do you recommend to clean the surface that will not damage the paint prior to putting on a new badge?
WD 40
