I know this is an old thread but better than starting a new one.
Reminder to check your drainage holes. Washed the car today, took it home and waxed it and then went for a cruise in my sexy, sexy 996. Turned on the ac and Bam! Smelled like a cat took a dump on my face. It was horrific.
Turns out something left me a nice gift in the battery box area. When I washed the car, it moved it all into the drainage hole where it decided to remain. Had to snake it and use the local car wash vacuum to try and suck it out and then ran water through it to try and flush. At least now I have a reason to buy a new carbon filter. I won't turn on the ac until I get one.
1 - Water drainage: sliding roof, rear
2 - Water drainage: sliding roof, front
3 - Water drainage: tank tray
4 - Water drainage: evaporator of heating and air-conditioning system
5 - Water drainage: radiator tank
Regarding this diagram, where are the exit holes for drains 1 and 2? Do panels need to come off to check these? I checked the drains under the frunk and all looks good.
after pulling material out with my finger , i used a long piece of soft coated (rubber/plastic) electric wire and snaked it all the way down and back up a few times, seems to have worked well
