4 wheel alignment specs recommendations?
Does anyone have any recommendations for what the alignment settings should be if doing custom settings?
Or is it best to just stick with what the OEM says?
I obviously don't want my tires to wear out super fast, but any handling improvements would also be nice.
I suggest you stick with a Porsche suggested alignment. Here are the specs for their various upgrade suspensions. If you do a search you will find all this information has already been posted. Welcome aboard.
![](http://i151.photobucket.com/albums/s140/Ucrazykid/alignment.jpg)
What are you looking to do?
- Just street driving?
- Light track and street driving?
- Setup for track, tolerant on the street?
Tire wear is all relative to your driving style as also your alignment should be.
These specs are really wide, and a good shop will be able to set you up with a selection, still within the factory recommended, to match your driving.
I posted my C4 alignment numbers a while ago for what they called Aggresive street. I was wearing my fronts badly on the outside shoulder... perhaps it was the AutoCross ??
I suggest the x74 settings. I have been running them for 2 months and they work very well on the street. I seem to be getting pretty even tire wear the car handles well and tracks straight. I am however running the x74 suspension too.
Originally Posted by Jonas007
Lets say the middle one. Basically I'd rarely track it, but want it to feel like a track car while on the street.
Tire wear isn't the issue, it is grip and balance. It sounds like you basically had them max out the camber front and rear with a stock suspension. There is a problem with this in that you have a lot more adjustment out back than up front. So this results in more grip in back than in front and increased understeer. This becomes an immediate problem...unless you like understeer. To stay closer to neutral you should only have about a -.5 higher camber out back than up front if you are running a stock suspension. -2 out back is too much for just running street tires. If you are running MPSCs, it is a different story. With MPSCs, you must run over -1.5 or they won't turn-in, grip well and you will just run the outer edges off. I run -1.9 out back, but my car is set up for MPSCs. I also run GT3 control arms to get around the camber limits up front. With MPSCs, there are dead even and with my pressures set correctly I get only a 3 degree variance with the pyrometer across the tire.
The same settings don't work with my street S03s or Corsas. With Corsas, which have similar grip to MPSCs, I actually run 10 degrees hotter on the inside than the outside. In fact, I wore one out on the inside edge from too much camber. I do also get camber wear with my S03s, but I just remount them flipped to balance out the wear. With street tires you just don't have enough grip to start with to use high camber. The sidewall never rolls as far and the outer edge never heats up as much.
