My little project for Friday night w/pics
My top idler and tensioner pulleys were becoming increasingly noisy for months now so I decided to finally change them. The bottom idler was smooth as silk so after $150 in pulleys, it was time to change them both or I was going to be walking. While I was in there I replaced the oil filler tube that broke during another project. Figured it was time to give the board some pics for once...
First pic shows how the slop in the bearing allowed the pulley to rub the stalk that holds the pulley.
95 degrees tonight and working on a hot motor on my knees, doesn't get any better than this....gotta love it!
Oh yea, the pulleys were the culprit, the motor sounds so quiet I can hear the injectors ticking.
Originally Posted by blinkwatt
How exactly do you remove the pulleys?
I used a 15/16" wrench (should use a metric) on the tensioner to pull the belt off and I believe the idler that has the long bolt that runs through the alternator was a 15MM.
Used the 15/16" wrench and a 15MM I believe to back up the tensioner pulley and remove.
Porsche gives you a brand new bolt (male) and a indexing collar (female) for the tensioner pulley. The bolt comes from the rear and cant be removed due to clearance between the engine and the idler stalk so I reused the factory one. Really no need to swap it out.
Originally Posted by gota911
Cory - kudos to you for taking that job on! Thanks for the pics! Don't you just love the "cool evenings" in SA?
I've been hearing lots of noise from my engine lately. I was trying to decide if it was something related to the A/C, but maybe it is the pulley issue... is this common?
Mine sounded like a cheap bearing in the wheels of a skateboard once no load was on it. I dont remember what sounds it exactly (it was 2007) made when it happened, probably squeeky or rock-crushing sounds.
