subwoofer cover removal
I have done some searches here and on other boards and have not found what I am looking for.
My car has the sub located between the passenger and driver. The cover is facing the passenger and at this time I would like to remove it but can't seem to get it off no matter how hard I pull on it. What's the secret here?
Are there fasteners somewhere that I am not seeing or are the clips just that tight?
I am in the middle of a stereo upgrade and this cover MUST come off but it won't budge.
Please explain to me how to get this piece off!!!!
Factory sub.
The previous owner ordered the High End Bose system and in the Targa, the sub is located on the passenger side of the console behind the CD tray and forward of the air bag sensor.
The carpeted cover is on there very tight and I can't get it off and wonder if there were hidden screws somewhere.
Sub is in the same location on a 2002 Cab. I found one torx screw at the front of the sub (near your feet). But I also cannot find a fastener at the back of the sub (below your knees).
there are 2 screws one oin the front and pne at the back you have to pull the carpet back at the front egde of the sub, after the screws are out push down on the sub and pull it off
Assuming it is a typical bandpass box, I am hoping to add some fill to the ports, and eliminate some of the boominess. The rest of the system doesnt sound too bad. But the subwoofer (only bose could call a 4" woofer a subwoofer) has that typical Bose sound that makes my ears hurt.
FWIW, the sub comes out easily once you find the 2 screws. It's easiest if you pop-off the center console side trim piece. I took it off at one point when I was thinking about whether to replace it but never followed-through.
lfe/rcronin,
Any updates? I was listening to the White Stripes this morning and the Bose subwoofer sounded terrible. I would love to replace if all goes well for you.
Have a great week.
Bill
Boise
Have a great week.
Bill
Boise
It turns out it is not a bandpass as I expected, but a simple bass reflex box. Much easier to modify without screwing things up.
It is a plastic enclosure with a wierd shaped oblong woofer.
I have done a little experimentation with lightly stuffing the box (This has the equivenlent effect of enlarging the box), and I have tryed a bit of port stuffing.
With both in, the boominess is gone, at the expense of volume level, I think I over stuffed the port.
I need to buy some more appropriate stuffing material, and some dynomat to try and dampen the enclosure.
From what I have done so far, I am pretty sure it will be possible to tame this beast, but it will be at the expense of some volume at lower frequencies. For me it is a worthwhile tradeoff.
I am suffering from not hearing or driving my car these last 2 weeks.
I wanted to save 1200.00 on installation and do this myself and working on it on/off I have realized that it would have been best to leave this to someone else. Don't get me wrong, I have enjoyed it but there is a lot of information that I didn't have and had to wait on to finish this off.
....and it still isn't finished!!!
I got the AVIC-Z2 into the dash, got the wires tucked away, got the seat back in, got the dash put together and all that. Got it to turn on and went through all the fancy buttons and thought I was golden.
But- the speakers don't work. I am at a loss.
I have a JL Audio 500/5 amp that I put in the car and for some reason it only runs the sub.
I think that I need to re-read the booklet and teach myself more about frequency settings, BP, HP, LP, and the other features that make this work as designed. I am thinking that I may need another power source to run the speakers in the intent to define the mids, highs, and lows the way I want them.
So close and yet so far away.
It has also been dry and rain free for these last 2 weeks and when I get this worked out it will likely rain and I won't be driving then either.
Crap.
Crap.
