Well I didn't need to try to make my other screwed up thread work but I have a question about the AC controls. Some people have them on the very bottom and I wanted to know if that had to be done aftermarket or if there was some option on the 996?
I used the bottom slot. It just doesnt fit in the top slot. The piece you need is a trim ring and its supposedly only about $6-8...
I have an extra lower console and AC control unit so I am going to play with that in my spare time to try and fit something. If i butcher it then O well...
It's really simple...Pull off the side leather covers by pulling out from the back and forward...
Pull off the batwing, the slot, and the cd holder(they all just pop off)...Next pop off your console surround. It snaps off too but you may need something to gently pry to get it started. After this is off you should see the 2 screws holding the AC unit in. Undo them and pull it out. Disconnect the wires. Now you also have to do the same with the other item. Once all 4 of these things are out. You have to fish the wire of the AC controls down through the middle. You will see what I mean when you have it open. Grab it and pull it through and you are all done besides putting it back together.
If you want anything more detailed let me know...I might have some pics too...
