Passenger Window won't close last mm's
Coming back from a round trip Brussels to Prague stopped for gas and whilst I went to pay I locked the car and got the "beep" that something was still open.
So, we got back in, started driving and the wife heard a load of wind noise, basically the passenger window will go almost to the top but not then last little "automatic close" if you know what I mean?
It has also effected the central locking, so when I close the car it still thinks the passenger door is open and the internal lights stay on, I have bodged that by taking the correct fuse out for the interior lights.
Any ideas?
Any ideas?
I believe you can reset the window position sensors by holding the down window button down for an extra five seconds after the window has gone all the way down.
This 're-calibrates' the up/down position sensors.
Also check that there is nothing blocking the window from moving into it's correct up position, like a damaged piece of the rubber seal.
Hopefully that will fix your problem.
