996 Forum 1999-2005
996TT brakes on C2 ?
Old 04-21-2007 | 01:08 PM
turbo138's Avatar
turbo138
Default 996TT brakes on C2 ?
Hi,
Has anyone converted 996TT brakes on a C2 ?
How much work will it involved ?
Thanks.
Old 04-22-2007 | 03:27 PM
arenared's Avatar
arenared
It's a no-go because the spacing on the TT front calipers is different than the C2. You will have to change out the wheel carriers and a whole lot of other stuff. IIRC, the "other stuff" was about USD $2K not including the brakes or the labor.
Old 04-22-2007 | 04:03 PM
newport996's Avatar
newport996
correct...you have to get new hubs and carriers and misc parts....It was about 3k new in parts, not including labor or rotors and calipers....also, yo uwont gain that much in stopping power...but you will gain unpsrung weight which will affect acceleration, turning and braking. So what most people do is if you want more stopping power, change pad compounds and use a different brake fluid. The pad compound will help with faster braking and teh brake fluid will help to keep the pedal from fading due to heat buildup in the fluid. Or, you can get a Brembo or Stoptech big brake kit that will be low weight, larger diameter, and bolt directly on. Again, you wont get that much increased stopping power, just if you are tracking alot, you will dissipate heat better so no brake fade over long periods of dhard driving.
Quick Reply: 996TT brakes on C2 ?
