How do make my seat heaters work?
Greetings - -- I have a 2000 Carrera coupe that came with 8way power, but no heat or lumbar support - so, I contacted LA Porsche dismantlers and just bought a nice pair or 2004 Carrera seats 12way power / lumbar inflate and heat -- bolted them in and all works well, except the position memory doesn’t work correctly and I am have having a tough time trying to figure how to hook up the heat (they sent the dash switches without harness) - I am planning to only hook up the drivers side heat, unless the passenger side is very simple to do.
Many thanks in advance.
Take a look at www.dennisvogel.com and check out his article on adding heated seats to his boxster. I used these instructions to add the heated seats to my 2000 996. It has all the wiring diagrams, etc., info on relays, etc. etc. I don't know if this will apply directly to the 2004 seats or not. If you need them I can provide you a copy of the wiring diagrams for the seats, 2000 and 2004 so you can compare them. Let me know if this helps, GOOD LUCK!!
