replacing Carrera script with 911
Originally Posted by LVDell
Stan, Loren over at Renntech.org has posted many times the workshop manual page that shows location based on measurements.
I haven't visited Loren's site in a while, great technical information over there.
Cheers,
Stan
Basic Sponsor
Come one, come all.
Imagine, for less than $100 you can go from a C2 Carrera to a GT3TurboGTRS! Where else can you get that sort of upgrade for so little?
We got 'em...all you want.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
Originally Posted by rcg412
wow - didnt mean to stir anything up. just seems out of place on the back of the car, and everytime I see someone add the 911 script, it is not centered, and looks poorly installed. To each his own!
That's because when people get the sticker they take the numbers of one by one... 9, 1, 1 and try to place them back together.. that's *not* how to do it... it comes on rectangular sheet and you remove the *bottom* of the sheet to reveal the sticky part of the numbers.... then using proper placement of the rectangle sheet that contains the 911 you just stick it on... press and take off the outer edge and voila the 911 are in perfect place...
using the rectangle as a guide it is easy to get it perfect because all you have to do is adjust for positioning of the whole 911 vs individuals numbers...
DO NOT REMOVE THE NUMBERS AND TRY TO PLACE INDIVIDUALLY... if you do you've just botched the spacing.
Originally Posted by Eric - Plug Guy
Come one, come all.
In removing the Carrera script, the paint underneath is bound to be a different shade of the car's overall color (i.e., not faded). As i think about it, this removal would give me the chance to still display the Carrera name in a more subtle fashion, and wax over it without the problems of waxing around and between raised lettering. What do you guys think?
Why put anyting at all? For the person that cannot tell it is a 911, then they should be stoned...I debage everything I own...
I think the back of a 911 looks better without any sort of "label"...
