Sachs clutch any good?
Originally Posted by 1999Porsche911
If you want a good feel of the clutch, remove the booster spring from the pedal.
I recall hearing this years ago but forgot about it. I'd like to give it a try. How is the spring accessed and removed? I'll remove it and report back.
TIA Nick
TIA Nick
TIA Nick
Pretty easy to remove. Crawl under there and take a look. Only warning is that make sure you secure the spring before removing by inserting a pin or nail into the hole provided on the back on the unit. This will prevent the spring from coming out of it's housing when you remove it.
https://rennlist.com/forums/showthre...booster+spring
Note that pedal will be substantially harder to depress but it makes for a much better engagement feel and control.
I crawled under the dash and can barely move, let alone see clearly what needs to be done to remove the spring.
Any other hints will be appreciated.
TIA Nick
TIA Nick
I crawled under the dash and can barely move, let alone see clearly what needs to be done to remove the spring. If I understand correctly, I need to first remove the clip on the pin that attaches the male plastic clevis to the pedal. Then push the pin out and push a nail thru the hole in the plastic piece and pedal. depress the pedal, remove a clip on the cylindrical spring housing, remove the nail, then the whole assembly will be able to be removed.
Can the spring and plastic clevis be removed and the spring cylinder holder be left in place?
This operation, with or without glasses is at a range where I can't properly focus on what needs to be done so I'll need to get a good understanding of it beforehand and go from there. Any other hints will be appreciated.
TIA Nick
TIA Nick
Jim
