Coolant Question
Ran my car this AM after sitting for more than a month - started immediately and ran incredibly well. Temp was reading slightly more than 180 which is a little unusual, since I wasn't driving the car hard. Coolant level is just slightly low (just below min line, but present in the overflow tank). Should I add water, a mix of distilled H20 and Porsche coolant, or straight coolant? We're moving into Spring in the NE.
I figure by May, my car should be broken in - hit 1930 on it this AM.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
You may want to start monitoring your coolant after you top it off since the level should not drop at all especially at only 1930 miles (assuming it was topped off to MAX from the factory). I had the same problem and had the coolant cap replaced first, after like 7k miles it happened again and it was a hairline crack on the coolant tank. Mine is an '03.
- Ahsai
- Ahsai
1 Post
I noticed mine seemed a bit high this morning as well. I think she's running a fever. I'll watch it on my way home to see what happens.
I figure by May, my car should be broken in - hit 1930 on it this AM.![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
- Ahsai
- Ahsai
I'm going to top it off and monitor closely - although it may have been topped off at the factory or even at purchase from the dealer >1 year ago, some minimal evaporation might be expected. Thanks.
Good luck.
- Ahsai
It's still under warrantee - but I'll keep close check on it! I haven't seen anything on the garage floor - best of all, no RMS leak (at least not yet). After having it sit all winter, it's just amazing how really good this car is. I was so happy with driving her again, I put another coat of Zaino Z5-Pro on just for good measure!
I don't think the expansion tank being a little low would cause it to run warmer in our relatively cool ambient temps. Did you check the radiators to be sure they are free of leaves and debris? Before I drove my car for the first time this spring (a couple of weeks ago), I pulled more than a dozen leaves out through the left and right grills.
Poseur
Did you write that you are under 2000 miles on a MY04 car?? Gees,--why did you buy it? I hope to turn 10,000 on my 06 model that I've only had for 5-1/2 months!
1 Post
Ahh, that's right!
- Ahsai
- Ahsai
When you add coolant, use a 50/50 mixture. Don't deviate because warm temperatures are coming. Monitor the level in the tank and watch your temperature guage. If you find yourself adding coolant frequently, visit your friendly Porsche dealer for a replacement (or, I'm told that it's not a real difficult do-it-yourself project).
Good luck!
Originally Posted by VGM911
Several of us have had the same problem..., it's very often a cracked coolant tank. The bad news for me at the time was that it's not covered under the certified pre-owned warranty.
Good luck!
Good luck!
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Good Luck!!
1 Post
Nothing was blocking my radiators from what I saw. My pressure valve was up on my Cap/Tank however, I don't know if that is the problem. Also, I had the expansion tank replaced and hopefully it's still under warranty.
Originally Posted by manny_g
Yup, the pre-owned warranty did not cover my expansion tank either. Cost me $900.00 installed at the dealer
Drive your car as much as you can to avoid other problems which may result from the car just sitting there.
Good Luck!!
Good Luck!!
Newbies Hospitality Director
Yeah, it's just a weekend toy - I promise to use it more this season - I agree it really does need to be driven!
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
and....... "The check is in the mail"..... "Yes, I will respect you in the morning"..... and , of course..... "I promise I won't --- in your mouth"
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
