The Good News and the Dreaded News
Originally Posted by Porsche_Smile
if it's under warr. drive it like you stole it and hope if anything is going to happen to the engine that it happens when you have the warr. it's all gravy then.......
This RMS thing is a bit crazy. Because you have a leaking seal you think the engine may go, not so. The seal is a $20-$30 part. Its only a pain cause you have to drop the trans to get to it. And its just a leak when it does go bad. This is simply a common problem, but it shouldnt be an alarm that your engine will be a POS or something.
Dont worry about it, it will be fixed and will be a non issue. Dont read anything into your engine cause of a single leaking seal.
Originally Posted by LVDell
huh? wtf kind of logic is that?
nope, didn't come as anything else. Just asking what kind of logic it was. If you don't plan on keeping it past the warranty then if you treat that car "like you stole it" then you have nothing to worry about. However, if you do decide to keep it past the warranty, you best take better care of your car
The IMS (intermediate seal) as well as the RMS does not cause engine failure. A total loss of oil would cause the failure. But for a RMS or IMS to to fail and have all 9+ liters of oil escape is so remote it's not even worth thinking about.
the seal leak is jsut a leak nothing breaks becasue of it
when the ims breaks there is no oil leak before it goes , once it breaks all the oil comes out, theres little warning (slight grinding noise from the bellhousing area...ive seen one pre failure, you never really know) and even at that point your gonna need an engine
