996 Forum 1999-2005
Check Engine Light
Old Jan 28, 2007 | 09:51 PM
dwccfp's Avatar
dwccfp
Unhappy Check Engine Light
59,761 miles and the "check engine" light just appeared. I was moving her from the driveway to the garage for good night sleep and the check engine light appeared. Oil level is fine, never abused, never overheated. Is this just the warning that I am due for the 60,000 mile service? Any ideas before I take her in for a service?
Old Jan 28, 2007 | 09:53 PM
Rob in WA's Avatar
Rob in WA
Cap'n Insane the Engorged
Sometimes it can be something as simple as a loose gas cap or oil filler cap. Try those first, disconnect the battery for two minutes ( make sure you have your radio codes ) then restart it.
Old Jan 28, 2007 | 09:56 PM
VGM911's Avatar
VGM911
dwccfp,
I'm thinking that you might be able to put your mind at ease by consulting the owner's manual, and seeing what conditions can cause the "check engine" light to activate. These things certainly make us nervous, but keep in mind that a yellow warning light is typically not as serious as a red warning light (which often means that you should stop driving your car immediately).
Good luck!
cdodkin's Avatar
cdodkin
Go to Autozone - ask them to pull the fault codes for free using their loaner OBD II meter
The codes will let folks here do a diagnosis of the problem
Old Jan 28, 2007 | 10:12 PM
dwccfp's Avatar
dwccfp
Thanks Rennlisters, Took advise from Rob in WA. First checked the fuel/oil caps, no luck. Disconnected the battery for two minutes, reconnected and................ no check engine light!!! Thanks VGM911 for the info with the yellow/red issue, trust me I was nervous. If it appears again cdodkin I will check it out at the Autozone, although I will be in for service in the next 300 miles.
Thanks to all.
dwccfp
Old Jan 29, 2007 | 12:21 AM
cdodkin's Avatar
cdodkin
I'm about to spring for one of the OBD II meters from Harbor Freight, just so that I can have my own fault code trapping equipment on hand for the 996 and other cars.
I have an occasional CEL code pop up on my 986, which is non critical (fuel filler purge valve), and I need to reset it when it pops up every few months.
Worth the few bucks that they charge at HF, and it'll come in handy for other vehicles I'm sure.
Might be worth a look for you too.
Old Jan 29, 2007 | 12:41 AM
Nine9Sixer's Avatar
Nine9Sixer
were you moving the car when the engine was still cold? that's happened to me before (not on my p-car) when i started the car to move it and then turned it off quickly thereafter. i was told by my mechanic prolly due to unburned fuel or something. CEL went away shortly after that.
Old Jan 29, 2007 | 03:56 AM
M3killa's Avatar
M3killa
Sounds like you will need a new motor.
Old Jan 29, 2007 | 07:23 AM
C4CRNA's Avatar
C4CRNA
Everone should have a cheap code reader. Saves a trip to the dealer. Look up the code, decide if it's a fluke, erase it if you want and you are on your way!!
Old Jan 29, 2007 | 10:18 AM
dporsche74's Avatar
dporsche74
i agree, you can go to any autozone and get OBDII reader for 50 -100 bucks or buy online a nice one with all the bells and whistles for under 200, really a must have for all 95 or later cars,
codes are easily pulled and turns the CEL off,
A must have for anyone with or without car experiance for so cheap,
Old Jan 29, 2007 | 10:26 AM
rcg412's Avatar
rcg412
59K - MAF seems to go around that time.
Old Jan 29, 2007 | 10:44 AM
TT Surgeon's Avatar
TT Surgeon
CEL's in 996 cars are almost always emissions related. The emissions system is still covered 10 years/100,000k miles by law. My cats went at 30k miles after a CEL.
wross996tt's Avatar
wross996tt
Not all code readers are equal and not all can clear all codes. The best consumer software for this is Durametric...will even clear air bag lights. Cheap is not always best here. And guesing and playing the I think its this is just costly.
Old Jan 29, 2007 | 11:09 AM
blk on blk's Avatar
blk on blk
Thanks to all.
dwccfp
Not to scre you or anything, but just because it went away does not mean the problem is corrected. I had CEL issues and ended up with a new engine. Yes that is extreme, but my experience is do not mess around with this if you have eliminated the basic things like gas cap, etc as possibilities. You may have a misfire of a cylinder, may have who know what. Get it checked out.
Old Jan 29, 2007 | 11:29 AM
VGM911's Avatar
VGM911
This is a good point by blk on blk. I had a similar problem: I had sensed a slight engine vibration when the check engine light came on. Turns out that one side of the engine was misfiring, which was caused by a malfunctioning chain tensioner. Because cams were then "off," valve timing was then also "off."
Moral to the story: As blk on blk said, get it checked out.
