Getting new engine. '03 996 C2 w/22K miles
#61
Originally Posted by rmillnj
I don't know about the rest of you but I am approaching 90,000 miles on my '99 C2 and about to come off of warranty in July. I actually kind of hope my engine dies in the next two months so I can get a new one and have two more years of warranty.
Only problem is the damn original engine just keeps chugging along nicely. Reading through the forum it just seems that most engine failures occur at the lower miles. Maybe we should have a poll to find out the highest mileage where an engine goes.
#62
Originally Posted by itorque
If you make it to 90Km the motor will probably go on like the energizer bunny. For the 03 years there was an inermediate shaft problem that shows up around 22Km which is what happened on this post and with my motor. Almost exactly 22,000 miles the motor sounded like ball bearings shaking in a coffee can.
Example - http://glenn986s.zoomshare.com/0.html
92,000 miles, same old cracked cylinder head issue from the early M96 block, bank 1-3 fails due to stress fracture/quality control issues.
It's a lottery on pre-01 engines
#63
For all you knowlegable guys: What usually goes wrong with these engines that makes them fail? Do the internal parts fail or it is something worse. Have the actual blocks on these engines cracked before?
What makes the engines in the TT or GT3 so bullet proof?
Manny.
Manny.
#64
Well its not like they are a weak engine.....what makes them fail is on early ones, the oil channels and coolant channels run next to each othern insode the engine block, the coolant over time would corrode the walls and then inside the block, oil and coolant would mix together....thats one failure. I think that one was resolved.....
#65
Manny.
Manny.
check the two magazine articles linked to from this page:
http://www.autofarm.co.uk/engines/water_cooled/press
It's poor design and quality control on pre 01 M96 engines I'm afraid
#66
Originally Posted by cdodkin
Manny,
#68
cdodkin: Great articles. Provided a good insight to the M96 engine and what can happen. For guys wanting to beef-up their engines with more HP, Autofarm provides a good alternative and at the same time strenghtens the block dramatically.
#69
I guess that I'm joining the fray.
I just picked up my car from the shop today after a 6-week "inpatient stay" to replace the engine following a coolant/oil contamination situation (I was impatient to say the least). The engine had 68k miles when it failed.
After reading all your comments, I now have to figure out if I will benefit from a 2-year engine warranty or not. The engine was replaced under my extended warranty (3rd party).
From a previous post on this thread, I'm taking that a break-in period is needed (~1000-2000 miles), right?
#70
Originally Posted by clum553946
Stephan,
If you don't mind me asking, how much did the rem. engine run you & how much for the install?
Thanks, Chris
Thanks, Chris
#71
https://rennlist.com/forums/996-forum/324510-engine-break-in.html
