failed smog test
Hi everyone, I have a 1999 996 with headers, chip, cat bypass, and fabspeed exhaust. Anybody know of a way to get it passed the smog without having to revert everything back? In the Sacramento area?
is your Check Engine Light on??
I am not sure about CA but here in MD they only connect the car to their computer, and if the OBD2 system is OK you will pass. I had back in the day a 00' Mustang GT with no cat at all and I still passed because I had installed O2 sensor cheaters. Maybe you could get something like that for your 911
The penalties for trying to sneak cars through that would otherwise fail smog are pretty severe.
In fact, my info is -- about a decade or so out of date -- is that the shop that did the mods for you could be liable as they're not supposed to be applied to a road car, only a vehicle intended for off-road (track) use. Some years ago I approached a shop about custom headers for my car (not a Porsche) and the guy accused me of being an uncover agent for CARB. Seems he was busted for doing custom though non-smog compliant exhaust systems by a I guess CARB sting operation and was paranoid and quite reluctant to risk doing any more. I didn't know that what was asking of him was illegal but as soon as I understood the situation I decided to let the car continue with its stock exhaust system. (I had removed the stock carb and substituted dual side draft Webers, along with installing a hot cam, high-compression pistons, etc.)
Sincerely,
Macster.
1 Post
You can probably pass if you put the cats back on. Did you run the car hard before arriving to the smog station?
Hi Lisa, I just passed smog with my 99 996. It has B&B mufflers and headers plus an EVO cold air induction system. I went to Stewart's Automotive. They specialize in British, Italian, and German cars. I highly recommend them. They are in downtown Sacramento and their phone number is 916-731-7023. I'm sure that you will have to put the cats back on to pass. Good luck. Mark.
just curious.... if one had on the 100 cel cats on will it still pass smog with headers and muffler and chip? and does anyone know how good are the Dansk cats? will they throw a cel?
Originally Posted by MechanicalEng
If in CA they perform a visual inspection you will have to get the cats back on...
