Seat stuck
I recently purchased a set of brand new 996 seats off of eBay. The driver's side seat is stuck in the forward position, and I can't seem to get it back to the position so I would be able to sit in it. The passenger side works fine. They are electric seats...but when I press the plastic ***** on the sides the seat doesn't change position. Any ideas?
Thanks,
Casey
Thanks,
Casey
Thanks,
Casey
Thanks,
Casey
Sounds like someone has had the switch over off and not replaced it correctly. It it truly is dead and not moving you can check it out by placing a knife down each side of the switch and pulling them outwards to remove the cover - do it carefully, as there are two springs that are on each side of the switch that seat into the holes in the cover. Replace everything and if you're lucky you'll get everything back in place and all will work well.
While you have the cover off you should be able to move the seat by moving the switch mechanism with a pencil or other appropriate device, just to prove that the switch is still alive.
Good luck!
Maybe I should have been slightly more specific in my original post. My seats aren't installed in my car yet, right now they are just sitting in my living room. The seat back rest is stuck in the forward position, where it would be so that stuff behind the seat would be accessible. I don't think this has anything to do with fuses, as I can move the passenger seat back rest forward and then back to the original position.
The seat is stuck forward in this position:
Nothing wrong. That is how my wife's seats look when I remove them to put in her GT3 seats for track weekends. The seat was "power" reclined forward and then removed. The manual latch up high does nothing more than move a more reclined seat forward to access the rear. However, if it is "power" reclined forward the manual will not be available to you.
Hope that made sense. When you hook up the harness to the car you should be able right away to move it back with the power button.
No problem. ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Only reason I know that is I went through the very same thing the FRIST time I reclined the seat forward and couldn't use the manual latch.
How far forward does the seat "recline"? My seat is all the way forward, and it seems odd that the seat would power recline that far forward, as it is impossible for anybody to sit in it's current position. Does the seat actually power recline that far forward?
Before I install my seats, I would just like to test them out to make sure that is the problem. Not that I don't trust you Dell, but I don't want to have to take them out again if it turns out that isn't the problem. Anyway, there are tons of wires underneath the seats, which color wire would I need to hook up to my battery just to test the power recline?
