Sound Deadening in Doors
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Originally Posted by kmorris_330
The windows do open slightly when the door is opened and close a bit when the door is closed. I think the sound of the door closing is very relevant. If you are unhappy with the exhaust you change it. Then why not the door as well? If I had a track car then it'd be different but as this is my daily driver I'd like the doors to sound solid. To each his own right? And yes it's my first Porsche.
The doors are already a water trap as they are in every Porsche model, but made a little worse in having no window frame.
Adding sound proofing may increase the door's ability to hold water, ruin your internal door trim and it may eventually start to stink. If the sound proofing starts to come apart it's likely to fall through the frame holes and end up jamming the window mechanism.
If you have leather trim on the doors it will even start to grow mold under the right conditions.
You would need to select your sound proofing material very carefully and don't use the Porsche stuff because that is the world's greatest sponge.
I also believe that you will not change anything by adding sound proofing anyway. Try draping a blanket over the inside of the door. This might give you a clue as to what you might be able to achieve.
The other choice is to sell the Porsche and purchase something with more suitable door closing sounds for your taste.
Ciao,
Adrian.
