996 Forum 1999-2005
Wheel offsets
Old Nov 28, 2006 | 06:17 PM
ReidN's Avatar
ReidN
Default Wheel offsets
I am looking at a set of wheels front and rear are 52mm offset will they fit without spacers? 8.5 front 10 rear.
Old Nov 28, 2006 | 08:31 PM
gota911's Avatar
gota911
Newbies Hospitality Director
Reid - first, I notice that you have a '99 C2. I don't know what the stock offset is for a '99 C2, so I will use the stock offsets for the '01 - '04 C2 cars (50mm front & 65mm rear) as the basis for comparison.
The front wheels will fit OK. The front wheels will extend an extra 4mm versus a stock 8" wide wheel with a 50mm offset. However, the rear wheels will extend an additional 13mm versus a stock 10" wide wheel with a 65mm offset.
There were a couple of guys on this forum a while back (6 - 8 months ago) that went with 52 mm offset on the rear wheels and the wheels and tires stuck out beyond the rear fender. They tried more negative camber, and went with smaller (narrower) tires just to minimize the potential for rubbing against the fender. None of the measures were successful. The "smallest" offset I would go with on a 10" rear wheel is 58mm. FYI.
Old Nov 29, 2006 | 08:03 AM
ReidN's Avatar
ReidN
Gota911 Thanks for the heads up!!
Old Nov 29, 2006 | 03:11 PM
Russ Murphy's Avatar
Russ Murphy
I've got 52mm offset rears and they fit perfectly, but.....
thats with 265's and 1.5 degrees of negative camber. Stock camber and 285's is probably not so good as gota911 points out.
