Car Sprayed Gas
Fuse
Originally Posted by 99firehawk
FUSE E6 .............IF IT BLOWS AGAIN LET ME KNOW AND ILL TELL YA WHY
How about telling us why even if it doesn't blow again?
firehawk - you rock. i see your posts here all the time and they are short and sweet, but they always seems to be right on the mark. next time im at the collection, how do i find you?
if you want3ed to find me, you make an apointment with ralph and tell him you want me to work on your car
< brad
unless you just wanted to buy a guy a beer then you can just come here ask ralph to get me for you
fuse e6 most common thing to blow this fuse is nothing to do with the orvr system but the infotainment system that shares the fuse generaly if t he car doesnt have premium sound the plug is loose undeer the console and gets rattled and hits a ground = popped fuse
Blown fuse can also be casued by shjorted reed switch, or shorted orvr valve all possible but not as common
< brad
onboard refueling vapor recovery (ORVR)
These systems are designed to capture the vapors displaced by the incoming fuel in the vehicle's vapor canister rather than releasing them into the atmosphere
well the first thing you should check is if you dont have premium sound theres a plug under the console that like to short out against the air bag ecu and blow the fuse, after that its hard to tell if it only does it once in a while
