996 High Oil Pressure
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
2000 Porsche 996 45k miles
A week after an oil change I started to get a high oil pressure reading on the interstate, 5bar +. I switch oil back to 0w-40 but had no change. I decided to see if the oil pressure relief spring was jammed. I pulled out the Oil piston spring, Oil piston and reinserted. Oil pressure settled back down between 4 and 5 bar.
The oil piston spring was replaced at 32K miles to fix a Low oil pressure light on. A 13$ part and a 2min fix for over 100$. I have and extra spring incase the old one goes bad.
2000 Porsche 996 C2 Cab
Eibach springs.
Short shifter
Fabspeed Exhaust.
Eibach springs.
Short shifter
Fabspeed Exhaust.
Range Master
Pepsie Lite
Pepsie Lite
Did you find out what this issue is? I ask because my 2000 C4 just came down with the same symptom. Does your car make any noise?
Installed a new oil pressure sender, 54$ 996-606-203-00-M100. Oil pressure back to normal! A 19mm 45 or 90 degree angle wrench would have made it a very easy to change. The sensor is located on the right side of the motor.
1 Post
Cool, I know who to call now when mine goes bad.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Actually, the part number is 996-606-203-01 (recently revised from 996-606-203-00).
I got one from Sunset for $35.77.
And it looks like the same damn thing they've been using since 1970. You'd think by now they could get it right.
