Need opinions on my next move. Xenons.
Originally Posted by arr0gant
How did you find $450 at Edmunds?
http://www.edmunds.com/used/2002/por...1/options.html
I selected the Xenons as the only option. As I mentioned, it did not show up as an option for the C4S, so it might be part of a package that is worth more.
I think you should just move on and enjoy the car. If you could can $450 great, if not, move pn.
I don't think you have a case. Bent Tree can just say that it was a misprint in the ad. You admit they didn't try to mislead you, they believed it had Xenons.
I don't think you have a case because you picked up the car in person. I'm no attorney but the law is "Buyer Beware" maybe you would have a case if you bought the car over the phone and did not see it until it was delivered to your home. But if you saw the car in person when you bought it, it would be up to you to notice the mistake before handing over a check.
You have a great car, enjoy it, after what you went through with the first C4S, I wouldn't worry about the Xenons.
Have fun and start driving.
Originally Posted by Nicolaasdb
come on....5K for lights and wiring??? I converted my 99 into a 02 with litronix etc.....the wiring harness new cost for the left side 450 and for the right side a little less of more....total about 850....new at dealer....
the litronix go on ebay for 250 per light to 1000 for the set...so total wiringharness and all would be under 2K!
You probably already got the the right wiring in your P and jsut have to pop out the old light and pop in the new lights...this takes seriously 5 seconds...there is one movement you have to make per light and the whole light comes out!!
So tell them to give you a grand and buy the litronix......and put them in yourself!!
I did it and if I can you can!!!
And start driving that F-ing car.......and they should give you a 1K for you to buy the lights!!!
Once again, i treasure the great advice I get here....and once again, I will follow it. I am going to start at $600+ and see what they do. If I get nothing, I will still be satisfied. THanks guys!!
Gant
Gant
Seared
Prolly = short for Probably.
"probably damaged" or badly scuffed.
Good luck with the lights.
Andreas
Originally Posted by AOW162435
At my advanced age of 37, I am way out of touch with today's street lingo.
Andreas
Andreas
Prolly is old... I was using it at least 15 years ago.
Gant, glad to hear that you're taking the right attitude on this. If you get something, that's great, if not, just enjoy the ride of the new car.
There is no retrofit directly from porsche but that does not mean you cannot put xenons on your non-litronic car. Sunset is out of their mind to estimate $5k. It doesn't come close to that. Just buy the lights (under 1000 for a set MAX, I have a set sitting in my living room actually) and the wiring harnesses and then you will be done... Its really not as complicated as it may seem
I have Litronics in my 996, but I put a set of retrofitted HID bulbs into my Lexus GX470 and bought a kit from here
http://www.xenondepot.com/category.php?category_id=3
Install is very easy, and since the headlights in the GX470 were already projector types, the beam from the HID retrofit looks as good as the ones in my 996. You basically get a kit where they've made (I believe H7 for non-litronic 996?) HID bulbs that fit into the existing OEM headlight housing. Then there is an ignitor/ballast for each of the bulbs, a relay switch to connect to the OEM lights for juice, then the main harness will connect to the battery (where the ballast and ignitor gets the electricity). Like I said, its an easy install, and work pretty darn good. Only thing its missing is the auto-leveling, so technically its illegal, but I've never had a problem in the GX470 passing inspection.
Let me know if you have any questions......Will
Ok, this seems too good too be true. Is it really this easy? Is there ANYBODY that anyone knows of anyone that has tried these in any 2002+ NON HID's?
they honestly just slide in the non litronix slots.....no need for a retro fit.....I put them in my 99 after convertion....simple.....you might have to wait a little for the right ebay offer! Don't pay 2-5K...noboddy can tell the difference...maybe only when you turn them on......spend the money on other mods...but than again you got a C4S and that one must be pretty complete!!
DRIVE DRIVE DRIVE!!!
The reason why XenonDepot was attractive to me was that they used genuine Phillips bulbs and ballast - some of the stuff on Ebay is of not great quality....you get what you pay for when it comes to these bulbs/ballasts!! And it really is that easy - can't talk specifically for the 996's, but on the Lexus forums everyone complains about a $50K car not having HID headlights, and there are a ton of folks who have done this upgrade with no issues/complaints...
Xenons are much brighter. I can see why they require the vertical ajustment.
