WTB 7mm H&R spacers.
where can i buy 7mm H&R spacers for my 2000 C2? i tried performance products in los angeles, but they are out of stock for more than a month already.
thanks
mar
thanks
mar
I bought mine from WheelTec in Miami.
305-252-2315.
$58.95 about 16 months ago.
FWIW, they were the only shop that had 15mm's in stock at the time I bought.......everyone else was on backorder from H&R.
They also have great prices on chrome lug bolts.
305-252-2315.
Originally Posted by mar2mar
mar
-td
thanks guys i really appreciate the help.
td-i like the 15mm for the rear too, but i'm not sure if the 15mm will fit with my 18" sport design wheels and 285/30/18 tires with out adding negative camber. also my car is lowered about 1.25"
thanks
again
thanks
again
Yep from drivewire......but I am still waiting (about 3 months now) for my front spacers!!!...I got my 15mm rear spacer from eibach...super easy install and pretty cheap..they come with lugs it think I paid for the front 7mm and the back 15mm total about 280. 15mm in the back look perfect!!
When I ordered my 7mm spacers from Performance Products I got the longer bolts too. Then the wheel shop who changed my tires a month later commented that the lug bolts for the porsche are supposed to have that "collar" on them. The stock ones did but the new ones don't. Does this really cause a problem?
JoeTanto - You need to collars on the lugbolts..its a PITA, but you can get them off your stock ones and put them on the new ones.
For those who got the Eibach 7MM spacers, do the spacers have the hubcentric lip on it to mount the wheels? or is it just a flat spacer - reason I ask is that I have the flat spacer kind (from FVD) and its hard to get the wheels mounted as only a portion of the hubcentric lip is showing after you put the 7MM on.....or does H&R's 7mm spacer have the hubcentric lip?
THanks,
Will
THanks,
Will
