MAF Sensor
negative cable is whats suppose to be removed, but no you will not hurt anything
u can unplug the maf with the engine running (not recomneded but i have done it 1000 times in testing) and not hurt anything. howerver if your cleanng it make sure its clean and dry before you plug it back in
Hi all. New to this forum and yes I will post pics of my car shortly on my webpage. My Rennlist website
So I finally decided to either clean the MAF or replace it as I was tired of clearing the CEL once a week or so but when I went to take it off I discovered that it is held on by screws that I do not have a driver for. Can I pick one up at the local autozone or pepboys? What do you call it. I can just see myself trying to describe it to the guy at the counter. Any help would be appreciated.
Thanks, Oscar
Thanks, Oscar
Here is the definitive thread on MAF (it's a torx driver T-20). No need to disconnect the battery (although if you do it's the NEG). If you have CEL you should get the codes as it may not be the MAF!!!!
http://www.renntech.org/forums/index...pic=414&hl=MAF
