Will 305/35 18s fit on a 18x10 with 45mm offset?
I got a set of BSA wheels for the track and I want to put some 305 TOYO RA1s on the back but I am wondering if they'll rub.
Do they in fact have 45mm offset in the back? What is the factory stock 18s offset?
Ditto from LVDell's comments. Stock narrow body 18x10's have a 65mm offset. I have seen C4S wheels on a narrow body and they do stick out. Since these are an inch more narrow, it won't be as bad. They will also rub if the car is lowered. You will have problems with a 305/35 on this wheel. It is too tall (1.3" taller than the normal tires for these cars). In addition, I would not recommend running that tire on less than an 11" rim. Those tires are about 2.5" wider than the wheel you are using. This is no problem in a straight line, but tremendous amounts of sidewall flex in corners. Don't be surprised if they rub badly on both the inside and outside if you choose to get these.
Former Vendor
Tire size is right... wheel is pushing it. We do run 40mm on the Volk Racing Track wheel in the rear which does fit on the cup race cars. So you will be close.
Originally Posted by okbarnett
The GT 2 has 305 on 12 inch wheels, turbos have 295 on 11 inch. But I have seen 305 on 11 inch and they look OK.
