The new K&N Cold Air Intake
Haven't seen any posts on the new K&N intake so I thought I'd share my experience so far. Installed the kit two weeks ago. I've attended a two day autocross since then, so I can say with certainty the intake is more powerful; I'd guess 5 hp (which could be anywhere between 2 and 10).
Unfortunately, there are more than a few drawbacks:
#1. Warranty stipulates that you must return to stock when it rains. This is no doubt due to the poor placement of the conical filter. Too bad I read this after completing assembly...
#2. Unit is shown (and no doubt tested) without the dry charger cover (keeps water out of the intake) but again, the warranty stipulates you must use the restrictive cover. I hate when marketing advertises one thing, and sells another!
#3. Materials and craftsmanship are poor. There are huge gaps for hot air to seep into the intake... The kit uses the factory intake tube without enough support to mate the intake from the tunnel to the deck lid... Had to run to the hardware store to get real screws, nuts and bolts...
#4. The sound is OK at low RPMs, but very annoying above 6000 RPM.
I will probably throw this system away.
Does anyone know about the EVOMS cold air intake?
thanks for the review.....I was waiting for one....thinking of buying the system...I have the fabspeed "coldair" intake...and am pretty happy with it...
Changing back to stock when it rains???? I you kidding???...so you got to have the stock parts in the trunk on a long trip! THAT SUCKS! and is stupid!!!
Agreed. I waved off the notion of using the K&N intake after reading a bunch of guys' complaints about build quality and mediocre separation from the engine's hot air. I'm still keen to get a CAI and have narrowed it down to the EVO version when the time is right.
Ironman 140.6
The huge hot air gaps are a potential problem I questioned since I first saw the photos. Then when people started reporting MAF problems that pretty much sealed the deal (not to buy) for me.
I think I may eventually get the Evo system for my 996. I have their intake on my Boxster and it has worked well for 4 years now.
The only problem with the MAF is that people were putting them in backwards.
Although there are gaps that would let hot air from the engine in, once in motion air should be coming in from the decklid forcing air in the engine compartment to go down.
I'm not saying it's perfect, there could definitely be some improvements in the design.
I have had mine in for a month or so in my daily driver and have had zero problems. My only issues with the system is the low build quality and a few missing nuts and bolts in the kit when it arrived.
Somebody explain to me again why people are installing these false hp claim poorly constructed air boxes in their car when the Porsche one is engineered and constructed properly? Oh yeah, and I don't have to do anything with my factory airbox when it rains since they already built that feature into the airbox to get rid of any water that should make it into the airbox.
LVDell has a point
I agree that installing another air box is silly, but for $300 it was worth a try. My X51 power option (25 hp) was $14,000, so I'll probably try the EVOMS set-up even though I've been burned by K&N. Worse case, another $500 down the drain. Best case, 10 hp without the fuss.
Has anybody compared it to a drop-in K&N filter?
I mean..at the end of the day the stock system is a cold-air intake (aka it only draws air from outside).
The rest of the equation is:
1) exposed filter surface area
2) piping diameter and how smooth it is.
3) filter material
From what I can tell...the conical K&N is probably not more surface area than the stock filter.
Gut feeling is that a freer flowing drop-in filter would give at least 80% of the HP gains of a complete system.
thanks,
Amir
3) filter material
thanks,
Amir
I now have both, Evo V-Flow and the new K&N - I agree with the poor build quality of the K&N compare to the Evo, the Evo looks better and has a better Cold Air BOX, The K&N simply does not ! Hot air must get in, I can't see how only cold air is force into the filter system. HP Gains, no sure, I have too many engine mods to notice 5-10hp - Throttle response in both kits are good. That's all folks - The bottom Line, The EVO is a much better unit PERIOD. !
Originally Posted by LVDell
Personally I would spend the $500 on 2 DE weekends
