After 4 weeks of porsche ownership.
Lets get back to this offsetting car geometry... I am also running the 997s wheels. The car feels much better, more planted in turns with the extra inch of rubber in the rear.
Now I am not taking it racing, are you talking about on the track its not as balanced?
So a 19" rim, with the same width and offset as an 18" rim causes a difference in geometry, just because it's 19"?
I don't see it
They may be referreing to the fact the the Carrera S rim has a different offset at the front by 7mm.
Now that could make a difference, but in practice I find it drives just fine.
If I wanted, I could add a shim/spacer and bump it out to the same as 996 spec, which cohare may have done?
Other than that I'm mystified
Anyone got any other thoughts?
Chris.
I don't see it
Chris.
I havent added the spacer yet because I have not seen a need for it either... Other than the offest difference I would have to agree I dont see how it could matter.
Originally Posted by cdodkin
Weight is the same as 18" I believe - no extra unsprung weight.
I've driven in LA, and so far no issues.
This is true!
I think with lowered suspension, you'd be in for a hard daily drive!
I am not sure about LA streets but I live in downtown Baltimore and the streets even feel $!tty in my 04 Maxima I know how you guys feel. No problems with the 19's yet ..knock on wood..
1 Post
Awh, come on! Ounces? I'm sure there are some very ugly lightweight forged 19" rims that are lighter than the stock 18's.
Originally Posted by Paul Marangoni
Not possible, but they're probably only ounces heavier.
You must have stock suspension then.
