Help! My rollbars popped
When I came off a rise in the road a little hot, and got a bit of air, my rollbars popped up and scared the crap out of me.
Anyone know how to reset them?
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Poseur
It takes a trip to the dealership.
Guys, quit scaring him! You do NOT need to take it to the dealer nor is it an hour of labor. Takes less than 5 minutes to remedy and is outlined in the manual.
Poseur
Share with us what the process is,--my manual says take it to the service center.
Poseur
your manual is a 997 manual. his car is a 996.
you are giving information based on a different car.
PAG changed that little part??
Man, you guys are brutal...Just reminds me of why I became a member of this great forum. LVDell is probably correct. I didn't take the time to RTFM.
However, if it's not in there I'll be back.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Alright, I'll save you the trouble: You take the car, disconnect the battery, turn it over gently, and using the weight of the car, let it slowly compress the rollbars until you hear a click. Reconnect the battery, start the ignition, and you are good to go.
Originally Posted by nycebo
Alright, I'll save you the trouble: You take the car, disconnect the battery, turn it over gently, and using the weight of the car, let it slowly compress the rollbars until you hear a click. Reconnect the battery, start the ignition, and you are good to go. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Don't forget to turn it back upright before you reconnect the battery, otherwise the bars will just pop up again
For those who haven't experience this its a bit of shocker - Like a .45 went off in the back seat just as you make contact with the ground again. Yikes!
