996 Forum 1999-2005
Cigarette lighter gives continuous power...
Old 06-30-2006 | 09:13 PM
Dutchie in NC's Avatar
Dutchie in NC
Default Cigarette lighter gives continuous power...
... so my radar detector (Escort Passport 8500) stays on all the time, and I guess will drain my battery. Any wat to fix this such that there is no power to the cig lighter after I turn the engine off?
Old 06-30-2006 | 09:54 PM
gota911's Avatar
gota911
Newbies Hospitality Director
Get your favorite beverage, do a search on "switched power" then sit back and enjoy an evening of reading about switched power.
Old 06-30-2006 | 10:55 PM
NNH's Avatar
NNH
Everybody has their own favourite way of doing it. I ran a cable along the top of the windscreen and down the A pillar to the fusebox, where I tapped into the heated seats fuse which is switched and has a hefty 25A rating. There's also a decent ground screw behind there. Other people dig into the centre console to find the phone wires. Apparently there is also a good switched wire somewhere in the sunroof area, but you'll also need to find a ground wire there. Took me about an hour and a half to do, and about twice as long to research beforehand!
Old 06-30-2006 | 11:28 PM
87turbolook911's Avatar
87turbolook911
You can connect your detector to your radios switched power or connect the positive lead of the cigarette lighter. The wiring diagram is on a label affixed to the radio.
Quick Reply: Cigarette lighter gives continuous power...
