Beware of this Dealership (long)
![Thumbs down](https://rennlist.com/forums/images/icons/icon13.gif)
I posted few days ago about my frustration with Stevens Creek dealership... Well it got worse when I saw my invoice yesterday. To quickly summarize, after replacing the coolant expansion tank and seat/mirror control module under extended warranty, went home to find out that my ignition switch was broken, cannot pull the key out nor lock the car down. Also noticed that a bolt was missing on the air-pump that the Tech had to removed in order to replace the expansion tank. This already showed how sloppy they are. For this one, I had to go back to them and asked them to make things right. The advisor candily said "that's a coincidence that your ignition switch broke-off while at our dealership", oh please!
It was working fine before and someone had to turn that thing ON/OFF many times with force that the springs inside had broken off, right? Let me ask this: How many of you had a ignition switch gone bad w/ normal use? I did not find nothing from the search engine.
Anyway, they replaced the ignition switch under warranty and for the missing bolt, they charged me another $75 to give me back my bolt WTF?
They said, that bolt broke off and needed to be fix huh? Have you guys heard about broken attachment bolt from the air-pump? I believe that thing has no stress on it, how can it brake from normal use? This car has less than 29k miles with no track history. This seems unethical and not good business to me. I will not go back there again, that's it. Though I must say that their customer service is good taking good care of giving you rides to and from work or home anytime. It could just be me, my bad luck, had a bad experience with this dealership but I want to share this with all of you to keep you alert of their business practices, anything to make few bucks even for the migthy Porsche delearship.
Thanks all for listenning...
Cheers,
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
![nono](https://rennlist.com/forums/graemlins/nono.gif)
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Cheers,
Hi Botsy,
I've read this a few of your other posts with puzzlement. I used SC for 6 years now and have not had anywhere near the problems you've had. I did buy the car there new (ordered it actually). Their customer service, while they're not falling over me, has always been above average in my experience and the workmanship, again not stellar, but always done well (and I check). Whenever I've had an issue, I brought to the attention of my advisor and it was handled in a prompt fashion.
However, now that my car is out of warranty, I do not use them as much anymore and have found a good indy (I'm also starting to do more of the regular maintenance on my own too). If an indy wrench is not the way to go for you, the next recommendation anyone makes is going to be Carlsen in PA. However, make sure you have $100 bills sticking out of each pocket before you enter that establishment lest they ask you if your Daddy is with you!![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Oh, by the way, this thread may help with your ignition problems:
https://rennlist.com/forums/996-forum/218902-ignition-problem-can-some-one-explain-this-to-me.html
Good luck!
Good luck!
Just a suggestion - call the service manager, and ask for the contact name & number for the local area rep for Porsche.
Give them a call, and lay out your issues calmly, stating that the dealership is not performing to the standards you expect from Porsche.
Explain the damage to your vehicle while in their care, and the poor service.
Ask them to call the service manager for a full refund.
Chris.
Chris.
![](http://www.d30-images.com/911/sig-strip.jpg)
Thanks Joe for your feedback... This is my first P-car and actually my first visit to SC and truefully I did not expect this at all based on their prestigious image and name. Since I have extended warranty I was excited to bring my car there and expect a good treatment from the service department. Again I think the overall customer service is good, but I was disappointed by their workmanship and lack of honesty. That bolt worth nothing and even if it broke-off as they stated (I don't believe it could), as a courtesy they should replace it for free. Mind you that they already pocket $2000+ from Warrantech and $800 from my pocket, looks like it was not enough... When I told them the Tech forgot one bolt on the air-pump, I though they would be apologetic and would offer a new one to replace it. Anyway, I am not sure yet if I should go the extra mile to try to get back that $75. As you said, if it's not for the warranty, I would not use the dealer. BTW I have a friend who is a master tech for Smythe Mercedes across from SC and he has always done a great job for the past 3 years on my 5-serie.
Thanks Chris again for your help and support. I am thinking about going back and talk to their general manager Mark Wood about this unethical behavior. Not sure if it's worth the time and frustration for a measly $75. It's true that this is more of a principle thing. I may write them a letter instead with some facts attached to it.
Cheers,
Cheers,
Botsy,
As Chris said, I'd take up with the GM.
As for the friend who's a master tech at Smythe, ah-ha!, ask him how he liked driving around (or was it fixing?) my e55 for the last three weeks!
Three weeks to replace a brake assembly - for a "service campaign", I think they should have had more of the parts available... Or at least not taken my car apart to find out they didn't have the parts available to fix it.
The bolt that broke off is common when doing the coolant tank. It is a 2 dollar part and takes three seconds to install. The back of the nut for the bolt is rubber which usually decays and cracks and thats what needs tobe replaced. It happened when I did mine picked up the new nnut for two bucks from the parts counter and put it in 3 seconds later.
Originally Posted by Joe2000C4Cab
Botsy,
As I previously stated, SC does not offer the best customer service or technical repair. I'd not go there for anything that is straight forward like an oil or tire change.
They should not charge you for the bolt. It should be part of warranty. I'd not let it slide. If you don't complaint, they will keep doing this.
Try Carlsen next time. I've found their service and repair work to be pretty solid.
I agree it is unbelievable that the air pump was not reinstalled with correctly with all the bolts. I assume the bolt you are talking about is like on top of the bumper and goes in vertically? If so it is very common for the rubber grommet on the nut to age and crack off requiring a new one. It is total BS for them to charge you for a second repair when the bolt should have been replaced when the coolant tank was done.
