GT3 wheels on C4S
The std C4S offset is et50 front and et45 rear. When equipped with sport techno wheels, factory 17mm spacers are used in the rear, thus they use a et63 rear in that situation. Hope that helps.
my C4S came with GT3 (Option) but the Offset is diffrent from the Wheels that come on the GT3, i have the Correct Offset 50/45 but it was an Option for Turbo/C4S from Factory
The fronts will work fine. For the rears, you will need wheels spacers. I don't think I would bother trying to put GT3 wheels on a C4S when you can find used Turbo wheels all over with a going rate of around $1k a set. If you could find a set of GT2 wheels with 18x12" rears, it would be a different story since they are made for a wide body.
