$150.00 for key programming???
My dealer has told me that it will cost me to reprogram the key on my 996. I want the doors to automatically lock when the ignition is turned on & also to lock when 5 mph is hit... he told me it will cost $150.00, it sounds high, anyone know how much it should cost, or where else I can go to get this done? I thought they just need to plug the car's computer into some controller & access & change this option, very simple? Can it really be $150?
Bascially they are charging you for an hour or so labor too hook up the PST2 and reset the values for these items. My dealer wanted an hour labor to attached the PST2 to turn off the airbag light. I bought the durametric PST2/OBD tool to turn off the light, but I don't thnik it will do the reprogramming you want. You might Email Durametric and see if it will do this as the tools is less than $200 and is very handy for other things.
My dealer in San Diego charged 1hr (~$100) to program a new key. So 1hr seems "reasonable". Seems they charge 1hr as MINIMUM for any job even the actual time is less.
- Ahsai
- Ahsai
The durametric tool is not a PST2. It is nothing more than a OBD reader with airbag light turn off functionality.
As for the door locks, if you have a GOOD relationship with your dealer then they should do it for free. Just talk to your salesman or service advisor. I had the locks set and the OBC turned on gratis by my dealer. Just depends on your relationship with the dealer. If you do NOT have any work done there and are not on a first name basis with your salesman and your SA then you are going to have to buck up and pay the $150.
Then your OBC is on. Some cars (like mine) didn't have that functionality unless you ORDERED it with the car but it's there. Dealer turned mine of gratis.....same with the locks. IMHO is should be gratis regardless on the locks since that is a "safety" type issue that the dealer should program according to your requriement.
I recently paid $150 to get a key remote programmed. The estimate was $150. It only took about 10 minutes (and would have been less if the tech got the numbers entered right the first time). I asked if the actual charge was going to be the $150 estimate. I was told, "Yes, we have to pay for the $30K tester (PIWIS) somehow."
If you have the outside temp, then you most likely have the OBC enabled, but you cannot operate it without the stalks or some hacked buttons installed. On later models, I have read that you cannot just get the OBC turned on and add the stalks. Don't recall what the complication was.
LVDell - I'm not sure that I agree that the Durametric is nothing more than a OBD reader with airbag light turnoff functionality. Mine gives significantly more information than any OBD reader I have seen, with specific codes note only for engine fiunctions, but also ofr airbag, security,etc., and look at hours of op etc. Since I purchased mine they have released 2 updates of the software (which are free) and added several functions. They are also working on the ability to bleed the brakes with ABS and enable the OBC.
I for one am happy that someone out there is trying to give us Porsche owners an alternative to the PST2 for $3,500+ or the charges the dealers stick us with. It seems that Durametric is commited to improving the functionality of the tool, and it cost only a little be more that a quality ODB reader. Just my opinion.
Dharn55.....ok, maybe I should rephrase. It is NOT a PST2 nor does it come close the functionality of it. Is it more than an OBD tool code reader? Yes. But with limited extra values to capture. Nice features but NEVER will it come close to the PST2.
Either (1) PAG engineered the system in such a way that software like this will not be able to do everything a PST2 would (think about the money they would lose) or (2) PAG will not allow this to progress to that point without serious legal manuevers.
Only a dealer can program a key. Independent shops with PST2's can not. I have a PST2 and I can not program keys.
Porsche requires that dealers contact PCNA and get an IPAS code to program keys, imobilizers, and few other things. My guess is that it is done that way for legal reasons as well as our safety.
Dang, I was going to go to a independent Porsche mechanic to get him to do it, but so much for that idea... so $150 is a fair price (excluding being buddies w/ the service advisor?) Its highway robbery! Anyone else get it for less, anywhere in So. Cal? I got this quote from Mckenna Porsche.
Mating a new key to a car: can only be done by a Porsche dealer. The mating process, as Loren describes, requires a code specific to each individual VIN that must come from PCNA. (if you're also mating a remote key head, it requires the bar code ID that comes with the head).
Selecting among the Auto Lock options: is performed with the PST2 (like the mating process) .... but I am not at all sure it requires the secret vehicle code. I believe it is an option process similar to using the PST2 to tell the car's computer that you have the child seat / air bag deactivation bar installed.
If that is all you need done (as opposed to mating a new key to a car), then at least check with an indy shop with a PST2.
Sorry for REHASHING this thread but I used the SEARCH Feature and found this.
I plan on taking my car to Rusnak Pasadena and asking them to turn the auto lock feature for me as well. I love have the locks engages when I hit the 5-10mph mark and unlock as soon as I pull the key out.
$150 seems crazy to do this.
Whatever happened? Did the OP get it done? Did the OP pay the $150? Need a follow up to this story!
Technical Guru
