acceleration issues....
I have a '99 996 with a tiptronic transmission. The car just turned 64k miles. a month or so ago I had a problem with an uneven idle when it around 2000rpm's. The tech said it was a transmission issue. Come to find out, somehow the transmission fluid was low. There were never any signs of leaks. Anyway, He did a complete transmission flush and refill and the problem went away.
I made a trip this weekend from NH to CT and now I seem to have a new problem. When I am I driving and step on the pedal to give it more gas, the car does go but really doesn't take-off until I hit 3,000 rpms. It is almost like something is not catching or something is slipping until I get to a certain point.
Just before this trip, I did smell burning rubber. Perhaps this could be a belt that is worn and/or slipping? I did have the serpentine belt changed at 60K serive. Any thoughts? Anyone think it could be the transmission? Any other tip owners have problems with their transmissions?
Thanks for your help with this.
You might try resetting both the DME and Tiptronic mapping.
To do that (make sure you have your radio code) disconnect the battery for about 5 minutes. This will force the DME to re-learn it's idle and acceleration maps - expect a little rough idle for the first few minutes. Likewise the Tiptronic will re-learn your driving and acceleration pattern.
Wait a couple of days and if the problem hasn't been cured then find a shop with a PST2 or a PIWIS tester and have then read any fault codes. Most aftermarket testers can read the DME fault codes but not the Tiptronic fault codes so that is why you will need to find a shop with a Porsche system tester.
this kind of "hard reset" will damage my car in any way? besides i have to input my radi code.
I did drive the car really hard all day the day before this started happenning. I was at a car control clinic and drove the car harder than I ever had. Perhaps the car still thinks I am driving that way. I'll try the reset and see what happens. Thanks.
Originally Posted by pl
loren,
Small tip, most cars have their radio code handwritten by the assembler on the option sticker on the underside of the front hood.
Good luck.
I diconnected the battery for an hour or so to reset some things but it didn't seem to help. I'll take it to the shop later this week to see what they come up with. It seems to be shifting too fast - it gets into 5th gear before I hit 50mph if I don't push it. When it is in fifth and I step on the gas, it doesn't always go into fourth and sometimes feels like there is an "overdrive" kicking in. It always happens at about 3000rpms. The transmission itself seems to be running and shifting smoothly. Hope it is just a belt or something that is slipping. Any thoughts or guesses before I take it to the shop?
my tip does exactly the same in 5th before 50mph...this is normal...when I kick it on it's tail...it shifts back...depending how hard I kick it 2-3 gears....the car feels sluggish when driving normal....this is a normal P tip thing...so I have read....I don't think there is anything wrong with your tip....this is just the way it is
Thanks for the reply, but I've had the car for a year and it didn't seem to act like this until recently. Even if I am running in manual mode, the gears don't kick-in for a couple of seconds. It is almost as though something is slipping up until a certain point. Maybe I'm just being paranoid.....I'll get it checked out either way.
1 Post
I bet it's the maf. I never had this issue with my Pcar but my MB SUV had the same problem. I even had the tranny fluid changed and it actually got worse. I have the change the MAF and that fixed it.
Good Luck.
P.S. My check engine light never came on.
Good Luck.
Originally Posted by GoodSpeed Sweden
I agree with Nicolaas. Mine does the same if I drive smoothly. It is supposed to adapt to your driving style. Smooth driving=quick up-shift to 5'th.
