996 Forum 1999-2005
Techart springs????? Help
Old 03-24-2003 | 01:41 PM
Johnny996's Avatar
Johnny996
Post Techart springs????? Help
I am hoping that one or some of you may be able to help me out.
I want to "lower" my 2003 996 because there is an excessive gap in my wheel wells. I do not want to spend the $$$ on coilovers because for regular street driving they are overkill. I was wondering if anyone has these springs or seen them in a car and how low the car actually sits - the Techart site says 35mm. I already have the european sport spring and am slightly lower than stock height. How much lower will my car sit and what will the gap be after the install??? And are these springs any good?????
Thanks in advance.
Johnny.
Old 03-24-2003 | 09:33 PM
TrackJunke's Avatar
TrackJunke
Post
Just so you know, if you go to low your shocks may prematurely wear out. The shocks are most likely not made to run with springs that low, you should talk to someone that has done this. Personally, I would not just to do springs. Do it right and either do coilovers or a matched spring and shock combo.
Quick Reply: Techart springs????? Help
