Leather dash problems.
Need some advice. My 996 has the full leather dash, color is Natural Brown. On the top of the dash, in one area toward the base of the windshield on the passenger side, the leather is bubbling/wrinkling in one spot, probably about 6 square inches.
I don't understand why, as the car's history has it in garages most of it's life, in fact it's a 2001 with only 16,000 miles, and 10,000 of those I've put on in the past 1.5 years, so I don't see it as environmentally caused.
Any others have this problem? If so, what'd you do? Other than this, the car's pretty much perfect, so this sticks out.
Something tells me replacing this part of the dash is not going to be an inexpensive proposition.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
i have seen this before. When I was looking to buy a 996 a few of the full leather cars had a slight shrinkage of the leather from direct sunlight. I have attached a picture of one area (different than yours)but have seen it in the spot you are describing too.
I don't have any idea about how to fix it other than go to a shop that installs leather interiors...
good luck,
mark
good luck,
mark
Yeah, that's why full leather is a dumb option IMHO. It's inevitable that it will happen, honestly I don't even get the point. The dash should have been something like MB-tex. You could try some neatsfoot oil, but 100:1 says it won't work. If you have a leather dash you absolutely MUST use a sun shade in your windsheild, even if you are just buying groceries, always use it.
I've seen it too - on my car.
My windshield had a stone chip, and I got it repaired at one of the places where they fill out the hole with glass and harden it under bright and warm light.
I didnt notice till way after, but the wrinkles were in that exact area where the light shone.
Originally Posted by wross996tt
You must use 303 Aerospace to protect from the UV rays. I'm in Colorado and I know about UV...it will destroy the leather (lexol will NOT work).
Phil
Its a common problem, I know the car is out of warranty, but try giving PCNA a call. I am sure this is a TSB about this. only way to repair this is a new dash, and its pretty common for it to come back. If that fails you can always pull out the dash , and get it repaired.
I've got a my full leather dash has 65k miles on it with no signs of wear. I'm glad you guys brought this up. I'll definitely start using a sunshade and check out UV protectants.
Wross, where do you purchase the 303 Aerospace?
http://www.detailcity.com/303-aerospace-protectant.html
use detailcity in the coupon area for a 10% discount.
