pedal mod done w/ pics
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Just finished my Ultimate pedal install...very easy mod w/ nice reults.
Only minor complaint is the visible screw heads, thought they should have supplied more recessed ones. I don't know if worth trying to paint, it might just rub off.
Pedals look great, nice mod.
I got in on the group buy as well and just finished installing mine. I elected not to install the rubber inserts (personal preference really), although I did purchase them. I used smaller bolts and screws than were supplied with the pedals...the supplied ones were too big to recess far enough into the holes for the look I wanted. Smaller ones really blend in well and don't stick out above the metal - you might try that.
Only problem is he does have the rubber inserts, so smaller metal screws will not blend in. I got black screws and they blend in well. Yours look like they blend in well also.
I installed RHD version, I think only footrest is different
The clutch pedal assembly was moulded plastic, with much thinner pedal area than the metal brake pedal, very easy to drill
