996 Forum 1999-2005
How hard is it to replace an alternator?
Old 04-03-2006, 12:07 AM
bowmanm98
bowmanm98's Avatar
Default How hard is it to replace an alternator?
I think my alternator is gone since neither one of my batteries will hold a charge. So is it something I can do myself with simple hand tools or should I just take it to Porsche? It wouldn't be just the belt though because it would over heat right? Where can I get an alternator? Do they have aftermarket better ones?
Old 04-03-2006, 03:20 AM
djantlive
djantlive's Avatar
You should properly diagnoise this before replacing parts. How many volts are you getting when engine does run? Have the car jump started or charge the battery w a charger. If the battery doesn't charge with a charger, the battery needs to be replaced. If you start the car and voltage is under 13v, then alternator is weak. Clean up the battery connectors with a battery terminal tool to avoid poor connection.
If alternator does need replacement, I'd probly let the dealer or indept shop do the job. It's probly a job best to do with a lift. I bet they only charge an hour of labor so that isn't too bad.
Old 04-03-2006, 04:51 AM
toddel68
toddel68's Avatar
Most of the time it's only the regulator which has gone faulty. Porsche will only replace the whole alternator. I had this done at the dealer here in Germany and it cost me 600 € instead of 50 for a new regulator which I could have changed myself. (Well, it's live and learn) Don't know about outside Germany but here you can get it at the Bosch service or maybe you can try an independent alternator repair shop.
Thorsten
Old 04-03-2006, 07:21 AM
C4CRNA
C4CRNA's Avatar
I heard the part here in the US is $900.00 so you should be sure before you change it.Dead batteries don't hold a charge.
Old 04-03-2006, 10:23 AM
zman53
zman53's Avatar
Just had mine replaced by an independent from Germany. I asked him the same thing about replacing just the regulator, and was told if a wanted a new part, they are only sold together. Since I only had the car for 2 weeks, the dealer was kind enough to pick up the tab for me.
Old 04-03-2006, 10:39 AM
LVDell
LVDell's Avatar
had the same problem here and thought the same thing. $50 later and a new Costco battery and I was back in business!
Old 04-03-2006, 10:49 AM
1999Porsche911
1999Porsche911's Avatar
Alternator is easy to replace with everyday tools. Less than 1 hour job.
Old 04-03-2006, 12:58 PM
bowmanm98
bowmanm98's Avatar
Well I have two batteries. The race battery was in at the time and it started failing after about two miles. ABS went out all the lights went on, etc. Then I put the stock one back in and it was fine. I noticed it was a little low when I got to my destination. I left after a couple hours and the thing was super low this time with the lights on. Barely made it home. Two batteries both now super low. Pretty sure it's the alternator.
So should I buy one and do it myself? What do you have to do? Do you need any special "Porsche" tools?
Old 04-03-2006, 01:35 PM
1999Porsche911
Check the output of the alternator before replacing. If it is putting out 13+ volts, then it is not the alternator. If you do need to replace, it is a simple task and just like removing one from any other engine. You may even find a shop that will rebuild it for you. Shouldn't take you more than 1 hour to remove and reinstall. The only special instruction is that when you remove the bolts, you have to turn the alternator counter clockwise to clear for removal.
Old 04-03-2006, 01:59 PM
Tool Pants
Tool Pants's Avatar
http://www.renntech.org/forums/index...&hl=alternator
Old 04-03-2006, 03:37 PM
bowmanm98
bowmanm98's Avatar
Another thing I noticed was the belt was making a lot of noise right before all this started.
Old 04-03-2006, 05:19 PM
1999Porsche911
Well, check the belt. If it is damaged it may be slipping and is what is causing your problem.
Old 06-01-2006, 06:23 PM
vette67
vette67's Avatar
LVDell,
Where did you find your voltage regulator???? I'm having a hard time sourcing one for an '00 Cab-4
TIA
Old 06-01-2006, 06:28 PM
bowmanm98
bowmanm98's Avatar
Oh yeah, this thread...
BTW I too it to Niello in Rocklin to their new facility and wow I was impressed. They only charged me 2 hours which @ $125 per hour is totally worth it. They quoted me $400 for the alternator though so I got a remanufactured core exchange one for 200 or so at another place. So worth it. They also turned off my airbag light for free and cleared all my codes. The best part is this alternator works better and keeps my dry cell 14lb battery charged to 14amps. That's really good. I can install coilovers, sways, exhaust, but engine stuff is too much for me. I think the job cost me $450 total.
Old 06-01-2006, 07:55 PM
LVDell
LVDell's Avatar
vette67....I bought a battery not a regulator..
Quick Reply: How hard is it to replace an alternator?
