Rear Wheel Spacer issues with SSR GT3
I recently bought these wheels from Tirerack which are truly awesome ( pic coming later )
However, with the spacers that I also must fit, the SSR wheel has no cut outs on the inside of the centre block to accommodate the raised spacer bolts (I'm using Porsche spacers)
Do you know of either spacer bolts which are flush with the spacer (i.e. do not protrude) or a separate spacer which has these.
Solved this by buying 5 bolt spacers to reply the 10 bolt unit, it would appear that its safe with the longer bolts, Anybody ever experienced wheel separation ???? with longer bolts
