early 996 advice
early 996 advice
Hi All,
been lurking for a good 9 months now, enjoying the chat and piccies and getting closer and closer to the ultimate purchase
Great resource here, so thought it was about time to pick some brains in between my searches..
Here in the UK, ( so I'm in £ not $ ), I've noticed in the past few weeks, quite a lot of 'cheaper' 996s coming on the market, ie in the 22-25k mark.
These all seem to be early cars, 98/99, 70kish miles, generally with the original alloys and 'orange' lights.
Is there anything obvious I should be looking at with these cars ?
They look pretty good value, especially compared to similiarly priced 993s...
Roughly what mileage should things like suspension and clutch be changed ?
How much would it cost to convert to the 'clear corner' type indicators ?
And how much is a standard set of 18inch alloys and tyres going to set me back ?
Any other obvious gotchas ?
Obviously I'm aware I should get the best car I can afford, but some of these lower priced cars look a great deal, especially when I think they cant slip much lower, and hence be pretty depreciation proof...
Can anyone thnk of a really good idea why I shouldnt get something at this end of the 996 market, rather than say a late 99 with maybe 50k miles on it at nearer £30-35k ?
Any opinions on metropole blue interiors ? And how hard would it be to change the boot/hood release levers ?
cheers all
Toby
cheers all
Toby
Good luck
yepp, well, aware of the RMS issues, and not to worried about it...
I've done lots of searching over the past year but prices are always in $ and I was kinda hoping there might be some UK guys here with an idea too...
thanks for the pointers tho
Whatever you buy make sure you have a Pre Purchase Inspection (PPI) done by a reputable Porsche shop before you hand over your cash.
Try and get one with a detailed service history if possible. I would suggest you stay with a more conventional interior. Many times the "bling factor" wears off and you are stuck with something you absolutely hate. Can't go wrong with a black or grey interior.
Good hunting!
Good hunting!
Good hunting!
Good hunting!
Depending on where you are, donlt get JZ machtech to inspect it, they are a bunch of fools
make sure you get you local porsche centre to do it, even if it costs a little more
Any opinions on metropole blue interiors ? cheers all
Toby
Well, the car I went to see today, ( well cars, 5 of, all nice, like all P cars ... but one caught my eye ), was ocean blue with metropole interior, and it seemed a lot more subdued than I thought..
Not a bad combination really..
And certainly not as bright as some of the blues I've seen in 993's
But I've come from the typical black / grey interior cars...
It was missing the original stereo too, ( aftermarket fitted ), is it easy to change the centre console for a more modern or different one ? Maybe even to put an orginal stereo back in ?
The link below will take you to a siet that has many color choices in a neat gallery, including this one with a painted center console.
http://www.whiteson.org/boxster/gall...56959384.shtml
The notorious gotcha is the for this car is the rear main seal (RMS). From what I have heard it will cost $1500-$2000 to fix. If you end up having to fix the seal, it might be good time to think about the clutch (IMO).
Mark
I have a '99 coupe tip that was built in Feb-98. I bought it in Jan-05 with 35,100 miles on it. Rear brake rotors and pads were brand new. It had no leaks and no history of RMS failure. During the first year my repairs included the following:
1. Shocks replaced - At 7 years old, the seals on the shocks had failed and handling was scary. Dealer checked out the car and didn't find the leaking shocks.
2. Motor mounts replaced - The motor mounts are a nitrogen-filled rubber set-up and the nitrogen leaks out as the rubber cracks. Symptoms were a rough change from 2nd to 1st when stopped, remember, mine's a tip, and there was a noticable jerking when grabbing reverse. Dealer didn't find this either.
3. Front rotors ground 1x and brake fluid replaced - I was autocrossing a little and was being careful but fluid was 7+ years old, just like the shocks.
4. Power steering hose failed - see 3 above.
After 1 year, with then a total of 42,100 miles on it, oil and water were found to have intermixed. That's the big issue with these engines, not so much the RMS at a cost of $800 to $1,000. It seems to me that a good number of the early cases go porous and coolant mixes with oil. If enough coolant ends up in the oil, the bearings, rings and valves let you know in a bad way. Failure can be catastrophic. Mine wasn't but the engine still got replaced. Best solution is the higher-cost one: a new engine as opposed to a rebuild. I had an extended warranty and the warranty company bought the new M96 engine. All rubber hoses are now new and new Fabspeed mufflers are installed. Tip is now fully serviced. I'm giddy.
All in all, I love the car. It's Arctic Silver with a Slate Gray interior. I love the Ocean Blue but color is personal. Good luck finding the right car. A friend told me, "If you find the right car and it's $1,000 or $2,000 more than you think it should be, but it's the right car...buy it." What tipped the scale for me was the extended warranty. That paid off BIG TIME.
Cheers Guys,
some scary stories around ! Half persuading me to stick with my Audi tt...
Would a porsche warranty cover the main things tho, ie RMS, intermediate shaft failure, or this porous block thing ?
I kind of figured that a car having done 70k would have shown most of its faults by now... ?
Originally Posted by gdean2323
FYI: £1300 = $2261.35
