Another alignment settings thread
Just had my car re-aligned after installing PSS9s. Below are the specs. All seems right, but the car still pulls to the right a tad...
FRONT (in degrees)
Caster left 8.0
Caster right 7.9
Camber left -0.7
Camber right -0.8
Toe left 0.10
Toe right 0.10
REAR (in degrees)
Camber Left -2.1
Camber Right -2.2
Toe Left 0.10
Toe Right 0.15
Do the above values look acceptable?
FRONT (in degrees)
Caster left 8.0
Caster right 7.9
Camber left -0.7
Camber right -0.8
Toe left 0.10
Toe right 0.10
REAR (in degrees)
Camber Left -2.1
Camber Right -2.2
Toe Left 0.10
Toe Right 0.15
Originally Posted by ZBlue996Kam
You will need more negative camber in the front if you track your car and use track tires.
