Question for passenger airbag deactivation bar
Lifetime Member
Lifetime Member
Hi guys,
Installed the Porsche passenger airbag deactivation bar recently. The airbag warning light stays on no matter what. I do have the correct buckle that plugs into the plug, either pluged in or not the airbag warning light is constantly on.
Any ideas?
TIA
Any ideas?
TIA
Originally Posted by Robin 993DX
Hi guys,
Any ideas?
TIA
Any ideas?
TIA
If you performed the installation flawlessly (no key turned on) but have not yet had the central computer informed of such (using the PST2), then the airbag light will be on. The last step in the installation is to hook up the PTS2 and go through the menu driven selections to change the Child Seat Occupancy selection from "Not Active" to "Active".
Its all detailed in the TSB 6923 dated 3/5/99.
Took my indy mechanic (God bless him) about 5 minutes, no charge.
Lifetime Member
Lifetime Member
Kim,
Thanks for the input, I was seraching for a temporary solution before I had a chance to get the PST2 hook up. I was reading some information from a search on this subject. Someone was able to manually get the system to turn off the airbag warning light and deactivating the passenger side airbag without using the PST2. But unfortunately the procedures has to repeat itself every ignition cycle.
Just had the dealer install the deactivation bar - when I plug in the buckle from the seat, the airbag light blinks at me for about 2 minutes, then goes off for the duration of my trip. I'm assuming that's correct, since it would make sense to remind the driver that the airbag is off, but not drive him insane with a light that never goes off...
I've trained my 4 yr old granddaughter ( a daily rider) to check for this after I start the car .... as I have long since passed the point where I could remember such a task.
