996 Forum 1999-2005
18in Rim upgrade question
Old Feb 14, 2006 | 11:23 PM
luva911's Avatar
luva911
Default 18in Rim upgrade question
I have a 99 C2 coupe.
I'm upgrading stock 17 inch rims for BBS sport classic 18in rims.
Anyone know the correct offsets for the
18 x 8
18 x 10
Porsche owners manual shows the 18s as
18 x 7.5 with 50mm offset
18 x 10 with a 65mm offset
Found a set of BBS on ebay with the follwing specs
18x 8 52 mm offset
18x 10 65mm offset.
Is the offset correct for the front rims?
Thanks!
Old Feb 14, 2006 | 11:52 PM
TT Gasman's Avatar
TT Gasman
Yes, those are RoW offsets and will work just fine.
Old Feb 15, 2006 | 08:45 AM
yetis's Avatar
yetis
Is it possible to run an 18x11 in the back? I think this is what the GT3 uses. Is there any reason why this wouldn't work on a C4?
Front: (18 x 8) (Offset +50)
Rear: (18 x 11) (Offest +45)
Old Feb 15, 2006 | 11:15 AM
LVDell's Avatar
LVDell
The rear of 11" will work but not at that offset. Those are widebody offsets. The narrow body offset on the 11" is 63 if I am not mistaken (ala GT3).
Old Feb 15, 2006 | 12:43 PM
yetis's Avatar
yetis
Thank you Dell. After checking the GT3 forum, that looks right. BTW,thanks for the ML brake info, it went without a hitch.
Old Feb 15, 2006 | 12:44 PM
LVDell's Avatar
LVDell
Very welcome. Glad I could help
Old Feb 15, 2006 | 11:40 PM
luva911's Avatar
luva911
Thanks. Ebay rim has a chip on it. Will keep looking...
