X73 is in!!!
Just got back fron the dealer. Dealer's 12 miles away, but it took me 35 miles to get home
Many thanks to Chris and others who encouraged me. Even though it will be a while before I can take it to the track, it's already well worth it. When I went to pick the car up, it was parked beside a TT. Standing static, the car looks slammed, low on the ground. The 30 mm drop may not sound like much, but it looks like a lot on a car that was already low to begin with. On the move, the car IS stiff, flat, with appreciably quicker turn in. I can't wait to get it on the track to see how it performs, and also to see if it solves the tire wear problem.
I also wondered why they supplied a new set of engine mounts with the kit. The new mounts are taller, lifting the engine up a bit more in the engine bay. In conjunction with the lowering effects of the suspension, doing so keeps the half axles at the right alignment to the engine/tranny axis. Got'ta hand it to the Porsche engineers for covering all the bases. Good reason to go OEM.
I'm psyched!!
I'm psyched!!
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Side by side with the old, the new mounts were a bit taller. There's also less clearance now with the engine bulkhead. Maybe compression of the older mount made them seem shorter? New one's ARE stiffer, and the old butt sensor picks up more engine vibrations.
Won't be able to make it to the track 'til mid April. I was going to go back out again, when fluffly white stuff started to come down
. Me with street tires, track tires, but no snows
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Newbies Hospitality Director
Palting - WTF, no pics?!?!?! You tease us with "Standing static, the car looks slammed, low on the ground." and then you don't attach any pics???What were you thinking??? That is a big no-no!!!
Seriously, that sounds awesome. Can't wait 'til you get her on the track and we get a report on how she corners. BTW, about the pics... I was only serious!
![nono](https://rennlist.com/forums/graemlins/nono.gif)
Heh-heh, sorry about that, Tim. It's still cold, and snow is seriously coming down now. Car is safely in the garage with car cover on for now. First sunlight, I'll have pics with it languorously posing on the driveay or road.
Congrats Palting, the X73 will change your car forever. The reason for the stiffer mounts is to manage the stiffer ride, the stock ones would crack, plus Porsche wouldn't warranty any X73 stuff unless you put in the mounts as well. Yes, the engineers know their ****, you will love it at the track. My car never felt as planted at the glen until I got the '73, with sport cups you won't even be able to squeal the tires on a turn. Honestly, your tires will be fine now and you won't need that radical camber you were trying to get, the whole geometry of your car has changed back to the way it was meant to be, as per Walter Rohl! (not the dumbed down US version)
One thing, about a month or so after install, my handling went to hell in a handbasket. The car had settled another 1/4" or so and threw off the toe out, just get it re-checked before you hit the track. Do take some garage pics and measure the ride ht f/r now and in a month or so.
Enjoy, you won't be sorry!
Now for Jeevas.....
Now for Jeevas.....
Originally Posted by C4S Surgeon
Now for Jeevas.....
Palting, gald to hear you finally pulled the trigger, and it's good to hear your reviews.
So far, have not had any issues with scraping. Fingers crossed. I wouldn't mind the front lip so much, but the darn bottom of the engine seems awful close to the ground.
OK. Here's a pic. Too cold and too much snow outside, sorry it has to be in the garage. Pic doesn't do it justice., especially with the black under trim. You have to see it in person, and beside a TT or another 911, to really apprciate how much of a drop it is.
Looks like it is supposed to, did you get a chance to measure the ride ht f/r, wonder if it is the same as mine, looks it!
FWIW, mine hardly ever scraped, once I put on the aerokit, that lip hits everything.
Here's another interesting thing I found for those interested in the X73/74. After they installed everything, they took an initial reading of the alignment. The initial reading for camber was -2.05 !! I had then set it to the recommended -1.45, but it's good to know I can go up to and possibly beyond -2.5.
I'll get the tape measure and let you know, Chris.
I'm telling you, you ain't gonna need to go that radical, whole geometry has changed for the better. If you do, you can always slot out the mounting positions on the front end with a dremel or get some camber plates from fvd to get even more camber.
.... OK. Here's a pic. Too cold and too much snow outside, sorry it has to be in the garage. Pic doesn't do it justice., especially with the black under trim. You have to see it in person, and beside a TT or another 911, to really apprciate how much of a drop it is.
![](http://members.rennlist.com/palting/porsche2sm.JPG)
