instrument panel gauge lights not turning on??
Help, I got an '04 C2, when I turn the lights on at night, the gauge cluster lights (numbers that light up on the gauges) do not always come on! sometimes they do, sometimes they dont! They will turn on eventually or if I run over a bump, so I think its a loose connection, can anyone help me!?
P.S. the OBC screen always turns on, its just the gauge lighting.. i cant see RPM, Oil Pressure etc... when these gauge cluster lights are out!
Its an 04 Take it to the dealer, and let them worry about it.It could a few things, could be a bad connector , a loose wire, bad ground,bad relay...its under warranty let them deal with it
Newbies Hospitality Director
Just take a 16 oz. framing hammer and hit the .... no, wait, wrong fix..... what they said ^ ! Take it to the dealer and have them check it out.
by light switch, do you guys mean the actual round **** that turns on the lights from inside the car? or some kind of switch/relay/connection in the wiring? thx!
just for archive purposes, the instument cluster lights were fixed by the dealer. They installed a new headlight switch, the round **** that turns on the lights.
