Body shop says MASHAW bumper needs work
Originally Posted by kilrgt
I have had NO issues with My Gemballa items , well the hood does change shape a bit when its real cold, but fits great. I Wouldnt say all aftermarket products need allot of work, I will agree that most do. The price they told you is on the high side, but you spend the money already so spend a little more and enjoy it after its done.
Like everyone said all have various degree of issues... Execpt for a few companies that I would never use... They all look good if a GOOD bodyshop takes the time to prep them right. It's all about the prep...
I guess you live and learn. The body shop called me again and they are now saying that the wing fittment is terrible (he used a different word), and they want me to look at it before they go any further.
At this point I'm thinking I should just send the bumper and wing back, losing $300 in shipping, and go with the factory GT3 parts.
8-10 hours to fix a fiberglass bumper? or is it poly urethane? If its FG find another body shop or send it back. The savings in going cheaper aftermarket will be erased by the man hours these guys are looking to bill you. I think these body shop guys see a Porsche owner and dollar signs appear in their eyes. But either way there is definitely more work required to fit FG parts than factory and its way more fragile than poly urethane. and nothing fits like factory parts, the seams between the fenders and the bumper can vary and those can't be filled in without allot of work.
I had sidekirts put in by precisionporsche and one side was about a 1/8 of an inch longer at edge of the rear wheel well than the other side. OEM and aftermarket will not fit exactly the same even after the prep work.
MA Shaw GT3 Mk 1 bodykit
I had a GT3 mk 1 body kit, consisting of a front bumper cover, Porsche factory side skirts, and GT3 rear deck and wing. There were no outrageous problems. This was installed on my '99 996. The rear deck simply bolted on with little adjustment. It even came with the wiring harness adapter. The side skirts were Porsche perfect. The front bumper cover had some aluminum screen bonded into the openings. The bumper cover and screen were painted and the whole unit was installed without any issues.
Once again, I guess every installation is different. Michael is pretty good about eventually returning Email inquiries (instant- 1 week later). Good kit with no problems.
The aftermarket GT3 rear wing is a bit different, as it has two bolts on each side holding the wing. However, I did have the chance to bolt up a true GT3 wing to my "base", and it fit perfectly. I did have a modified 8 degree shim installed between. This was installed to use my own wing with the stock shim. It bolted right up to the stock unit, just the same. (The stock wing has one bolt on each side to fix the wing.)
No problems at all.
No problems at all.
I went down to the body shop yesterday to see what they were talking about. By this point they were complaining about the wing as well, and they wanted me to see if I was ok with how it lined up.
I don't think I'm happy with the alignment of the wing/deck lid.
The front edge has so little gap that its rubbing when you open the deck lid,
and the back part of the wing is sitting about 3/8" higher than the tail light:
So in other words, they can adjust it so that it won't rub in the front, but then the gap in the rear will be even worse. They said I can just leave it like this, or they can spend a lot of time changing the front edge so that everything lines up properly.
I don't think that this is what people mean when they say that all fiberglass parts need some work. Filling pinholes, etc I can see that being normal. But the part should line up better than 3/8" right??
There are two rubber standoffs under the rear of the deck lid that they didn't install because if they did it would stick up 1/2". This just all doesn't make any sense to me.
welcome to the world of aftermarket. i went through this about a year ago. you have to leave it alone or just decide to live with it. most people will never notice the improper fit. oem is the way to go if you want perfect fit. i have an oem front turbo bumper, anziano turbo rear bumper, and an anziano turbo rear wing. the rear bumper and wing are pretty close to oem, but there are imperfections that i have just decided to live with and nobody else seems to notice.
OEM is the way to go, mine needed very minimal work, only bc it was previously painted. I must say the misha wing I had needed quite a bit of work but nothing like that, I'd send it back.
Originally Posted by C4S Surgeon
I think all the aftermarket stuff will be about the same, might try a oem TT front, probably alot less prep work involved, although 800-1000 ain't all that bad. Karlooz has a similar setup, hopefully he'll chime in as well.
i don't have a mashaw bumper but i do have an aftermarket FRP bumper. qualility is 80% of oem, fit is 95%. if i had the '02+ headlight i probably would have gone oem. check http://www.sunsetimports.com/porscheatcost.php for porsche parts at dealer cost +15%. really good prices unlike local dealers that charge +30%~50% more.
