HELP! How do the A pillars come off?
Well its time to do some of the Carbon Upgrades, and I need to replace the front defroster vents(NOT SIDES) and I am curious to know if anyone knows how these things come off. I think ou need to pull them off, like everything else in out cars , but any advise would be great..
Paul
Paul
Paul
Paul
1. Remove the sun visor. It simply pulls out
2. Use the small flat screw driver to pry of plastic cover on visor base. When removed, you will see the Hex bolt heads
3. Use the 4 mm Hex wrench key to remove both bolts. Hold on to the part, it has washers on the other side and can get fall off if not careful.
4. Now pull off the A-pillar cover.
Hey Vulture..let me know when you plan to do that...I was planning on doing the same. My remote is so sporatic and when it does work I pretty much have to have the key a foot away from the car
Maybe you, Tim, and I can get together.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Originally Posted by Vulture996
looks good. I going to remove my A pillar and fool with the antenna to increase my remote distance.
The author based his DIY on the Porsche TSB. It only takes a few minutes after the A pillar trim is removed. I tried it with very good results. I suggest you use either the DIY, TSB, or both .... as the Porsche instructions are very specific on the length to which the antenna should be cut.
Originally Posted by Kims996Cab
The quote from the RennTech DIY, that I used above, is the first stage of a complete description on how to do exactly that.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
it may be worth it to come by and laugh at me while I
