CEL & hesitation in low Rpm's?
My CEL will come on intermittley, usually once or twice a day and also I have intermittent hesitation in low RPM's. Could this just be plugs? I have 52,000 miles and havent changed the plugs yet. I did just clean the the MAF.
1 Post
Sounds like a MAF issue but yes go to Autozone as stated earlier.. Someone here can tell you what the codes mean but often times the codes will read to be everything else but the MAF.
1 Post
Spark plugs causing a CEL, that's a first? Is this normal for Porsche? What happened at Autozone?
Originally Posted by will2769
Maurice, I used carb cleaner and was very carefull with the MAF. I am thinking its plugs. Because now for two days I have no CEL light.
I didnt think the CEL light was caused by plugs, thats why I think it may be plugs, no CEL light for 2 days. Didnt go to Autozone, because no light anymore.
Bad plugs can cause a CEL because it causes that side of the engine to run rich. The O2 sensor tries to lean out the mixture and reaches its limit. Result is a CEL.
